Picked up my LT Trail Boss today. The interior is very impressive and despite reading many comments on how uncomfortable the leather seats are, they feel really good to me. I said in my original post that I was getting Toyo Open Country AT3's put on it, but I put that off. That was a mistake. Like everyone said, the Duratrac's are loud right out of the gate. The truck rides amazing and the power of the 3.0 Duramax is awesome. I put 115 miles on it this afternoon and it was great.
  • Thanks 1
Awesome!  When was your truck built?  I have a zr2 silverado ordered...  status is 4b00...  so it's been built and sitting somewhere..  just curious how long it took yours to show up after the build date?
Where is the 12 volt power plug {cigarette lighter} in these new trucks? I haven't seen any in the videos, only the 120v in the bed and center console.
It was ordered on 12/27 and built the first week of March. Arrived at the dealer on 3/14.
I've looked and can't find one.
Wow. Strange that's been omitted. I'm thinking about my tire pump. Thanks for replying.
On 3/18/2022 at 7:50 PM, UCF w00t said:
They are supposed to honor it if it was a sold retail order. I have gotten the runaround with a previous order a long time ago because the window sticker that showed up had the new price and not the as ordered price. They ended up honoring it but took some bitching. The reservation email from GMC said it would be honored.
I called my dealer and asked if I could make a change to my order since it is still at 1100 and he said I could but it would take me out of line and put me in back and also that he couldn’t honor the price from January. I still haven’t determined if this is accurate or not. In a normal year, I’d request the change for sure, but I’m not even sure if I’m going to get one with the original order so I’m hesitant to do anything at this point.
Hi Rascal, to your knowledge.....is there a difference in the hoods?. I think the TB has a diff hood than others....thanks, as i mentioned i have an LTZ on it's way.
Yes it does. It has the same hood as the ZR2.
  • Thanks 1
Any pictures?
Just throwing some info out there for those of you with denali ultimate orders. I got allocation back in mid feb with a tpw of 4-11. Just found out today my tpw was moved up to 4-04 via gmc chat. That could change of course but its good news to hear. Makes me thing gm is getting ahead of this mess a little bit.
2022 denali ultimate, frost white, 3.0l btw
My ZR2 had a TPW of 04/18 and I just found out that mine was moved up to 04/11
Sweet man, the zr2 looks awesome. What color did you end up ordering?
Yeah i'm looking forward to getting it in my possession. I went with the Dark Ash Metallic. What color did you go with?
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
