I still do my own oil changes. That kid may do more than Ill do in a lifetime but if they are all done shabby....my few becomes better than his 1000.
Yea they definitely want an incompetent boob doing oil changes. Making sure you don’t come back for repairs. Makes sense to me.
You say it like that doesn't happen. It does not matter in the least what profession it is in, there is incompetence. The lettering on my tailgate has now been done three times due to it. The same guy gouged part of the plastic trim trying to fix my seat cover. That same guy also couldn't put the foam back on correctly. We have all heard horror stories about mechanics who seemingly forgot to put the oil back. Don't get me wrong, I am not saying it happens 10% of the time or any great number but it does indeed happen. It doesn't really suck til its you that has to be that one.
I’m not saying there’re all perfect. I’m my 66 years I’ve seen incompetence. Not everyone suited for the job. Have you noticed the last year in a half. It happens even in the most important occupation. I use to do all my work when I bought used vehicles they were usually beaters when I was younger first married. As I bought newer vehicles with warranty I used them for service. It’s easy to determine who’s at fault. Ifs there’s a problem. If they do all the work. I watch they know it, they probably have it on the work sheet. Because I’m a frequent customer. No problem doing your own work. Been there done that. I’ve moved on. At my age I do what I want. Oil changes for the most part, not on the list.
Yeah the last year and a half has just gotten more nuts than everything was. Im only almost 50 and have done my own since I purchased my first ride. Its cheaper for me to do it myself even though its getting harder to get under there. I do keep impeccable records though :D .
Yes, there are service folks at dealers that should be in another occupation.
There are also some that could be having a bad day.
Otoh, there are also lots of owners that should be told to 'back away from the toolbox'.
One of my fears when acquiring used vehicles/machines is that it might have been in the hands of one of those owners.
Just because they are very good with the appearance care does not mean that are good with mechanical servicing.
Very true, and it bothers me to no end when I hear "car wash" guys try to speak as though they are mechanics, and vice versa.
Just because you polish shoes, it doesn't make you a cobbler.
  • Haha 1
Specifically referring to the crank/no start situation. I have a ‘21 sierra 3.0 and it was doing the crank/ start situation as well as a few other things. I took it back to the dealership for repairs and they said they had heard of it and there was a TSB on the issue. Their first repair is a shim on the reluctor wheel, if that works your good, if not they have to tear the motor down and do some other repair. They did the reluctor wheel shim on mine and it has been flawless since then, almost a year.
Don’t believe they are even doing that anymore. It’s just an ECU reflash now which gets rid of the issue.
If anyone has a lead on the software for programming the lm2 pcm, kindly reach out to me as I'm planning a custom build for the near future and we would really like to use this 2021 lm2 and transmission in this classic truck. Sadly it's not the same as previous duramax mods.. im sure someone has found a way by now. Again im just looking for help on the software sode of this, Please reach out, and thanks in advance, George
  • 9 months later...
How'd this go?
2 hours ago, Ronjon said:
How'd this go?
GOcustoms joined and made the post August 21, 2022.
Last visited site Aug 13 2022 -- the day after the original post.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 268 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
