I have a 2022 Silverado 1500 LTD LTZ Z71 5.3L Crew Cab Short Bed, and I want to get a Borla Cat Back exhaust for it. Borla, and various distributers for the Borla exhaust, do not show a compatible exhaust for the 2022 LTD and distributers do not even have it as an option yet when configuring your vehicle. I suspect it's the same exhaust as will fit the 2021 model, but I contacted Borla and they can't confirm it and said they have not yet had a chance to check it. I don't want to order the wrong exhaust. Does anyone know if the 2021 LTZ and 2022 LTD LTZ models are the same regarding exhaust fit?
Any 2021 Silverado 1500 parts should work on a 2022 LTD model without issue.  The 2022 LTD is the same truck as the 2021 models, they have just extended manufacturing until they were ready to start rolling the new 2022 refresh out this Spring.
  • 2 months later...
Find out if the gym performance exhaust is the same pn on the new trucks as the previous. That would answer your question.
  • 1 month later...
i was just on Chevrolets web site and built a 2022 Trail Boss LT. There is an option for a Borla cat back exhaust system. Try to ask Borla again.
I have a 22 LTD and have the Borla S-type on mine. Love it.
LTD is the same as 2019-2021.  All of the Chevy Performance and the GM/Borla exhaust are the same P/Ns, even for the 2022 refresh trucks.
The refresh trucks is new front clips, new interior on LT and new vehicle electronics platform.  Everything underneath is un-changed.
Edited by newdude
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
