Is there any service bulletins on the oil filters coming loose on the 6.2 engines. Myself and another friend have a 2020 or a 2021 GMC Sierra with the 6.2 engine and both of us have had the oil filter come loose and oil leaking out and we caught it before the engine was a quart low. Both are 1500 and have the max tow package.
Is this the characteristic of this engine or just bad luck. Has anyone else experienced this.
Again: (thank you redwngr)
https://gm-techlink.com/?p=15777
New Torque Specification and Installation Procedure for ACDelco Spin-On Oil Filters
January 19, 2022
A new torque specification has been released for ACDelco spin-on oil filters installed on 2000-2022 GM models equipped with a gasoline engine. The new specification is in response to possible oil leaks coming from underneath the front of the vehicle after a prior oil change service was performed. In some cases, the oil leak may take several thousand miles to occur.
If an oil leak is seen, it may be coming from between the oil filter gasket and the mounting surface. (Fig. 15) The filter also may be very easy to remove, or may be able to be removed by hand.
F15-filter-2.pngFig. 15
The revised installation specification for all spin-on oil filters PF64, PF63, PF48, PF66, UPF64R, UPF63R, UPF48R and UPF66R is:
  1. Lubricate the new oil filter gasket with clean engine oil.
  2. Install the oil filter one (1) full turn after the gasket makes contact with the sealing surface on the filter mounting flange. If installing with a torque wrench, it should be approximately 10 Nm of torque.
The specification will be updated in Service Information and the label on the oil filters. (Fig. 16)
F16-filter-1.pngFig. 16
Refer to the Electronic Parts Catalog (EPC) to determine the proper part number for the replacement oil filter for the vehicle being serviced.
For additional information, refer to Bulletin #22-NA-009.
– Thanks to Bryan Salisbury
We'd usually just say hulk it on there. Because I swear the hulk himself put on some of those oil filters in the past when I worked in a shop.
  • Haha 1
I just had a similar occurrence on my 5.3.  While on the road I had the oil and filter changed at Mark Wahlberg Chevrolet in Columbus, Ohio.  The filter started leaking after I returned to Texas.  Classic Chevrolet picked it up under warranty, repaired it and cleaned the undercarriage.
  • 4 years later...
I have had it happen twice now on my 2020 gmc 6.2 sierra 1500, I'd get an oil change then a week or 2 later and after a 6 hour drive I am leaking oil when I get there, reach up and could easily hand turn the filter. Happened from different oil change locations as well with signatures and marks made on filter
NOT TIGHTENED PROPERLY.
What was the filter brand? If AC Delco, you sure it was a genuine brand. I know an AC Delco shop and he showed me a warning letter a while back about clones being found in some big name parts stores.
Some brands are just made cheap, gaskets and metal cans weak.  Business associate had problems when he went to cheaper filter in his shop and started to get come backs because of oil leaks. Filters were junk and he had to upgrade from some no-name cheap brand to NAPA filters (local NAPA store gave him best prices).
Never had a oil filter come loose on any of my 6.2L engines, never had one ever on any engine.
Edited by Z45
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
