3 hours ago, cansled said:
Nitto Ridge Grapplers 275/60-20XLPXL_20210617_171225007.thumb.jpg.7d7f648417cece95fab59b21be15a639.jpgPXL_20210617_171323634.thumb.jpg.59601b8e12916bd816d92200b9e2222f.jpg
truck looks great bro, how do you like those tires are they loud do they hum ?
edit: the stickers look good to, where did you get them from ?
Edited by Saso
Thx.  Tires are louder than stock, but not super loud or annoying.  I bough them because they are XL rated and not LT so they weigh about the same as the stock tires.  I towed my camper all last summer and they performed great.   I would buy them again.  Seem to wear great too.  Made the stickers myself on a vinyl machine.
once again the truck looks killer bro !!
275/60R20 116S XL Nitto Terra Grappler G2
(thinking of powder coating the rims black)
Like your graphics.  Nice work!
I got the same ones, for the same reason - great tires, quieter than the stock ones and look great
275/65/18 XL Nitto Ridge Grapplers
Like others have said not loud at all, more of a different pitch than the stock HT tires. You can hear them mostly between 45-60mph.
  • 5 months later...
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
