I cant find pictures anywhere with these exact flares installed.  Anyone installed them? They have a rectangular notch at the top of the flare and I am curious to see it looks with the body.
Welcome to the site.
Found this:
See the source image
Thanks.
Yeah that's the only one I can find.  Should have been more clear.  I'm looking for non-studio, like real life walk around pics.
Found this:
looks like the HD version where they would have an amber light in that place
Why would they do that? was hoping to find a GM one for my 22 like they made for my 17
I just ordered a set for my 22, Will post some pics when I install them.
I just picked up a new restyled Trail Boss last week with the 6.2L and the midnight edition, performance exhaust. I traded in my 19. Love the new interior and front end on this.
Edited by Mcandrew67
23 minutes ago, Mcandrew67 said:
Found some pics on GM site. Mine are supposed to come today, will post pics on my black 22 once installed.
That looks awesome!! Thanks for that
is it the same part number for the refresh?
Nothing has changed with the fenders on the refresh.
Mine came last night and I held them up to my refreshed 22 and everything lines up. No instructions in the box, waiting for the seller to send to me. I scoured the internet looking for install videos or PDF instructions with no luck.
Would you mind uploading pictures of the entire kit spread out?
Ok installed yesterday, zero instructions in the box. Couldn’t find any online or videos either.seller couldn’t even get from GM, he said they were zero help. I got them for $270. Well 2 beers and some cussing I got them installed. Love them.
sorry I didn’t see your message before I started install about taking picture laid out. You don’t need to drill any holes, but there are some tricky clips to figure out.
Thanks for uploading those pics, the flares look great.  Do you have a link to the website you bought them from?
Also, is it all mechanical fasteners holding them on or is there any adhesive involved?
Got them on Ebay, no adhesive other than the fronts have some tape pre installed. All clips otherwise, when you hold them up you can see the existing screws you will use, then the clips gon on the body behind the other holes and you screw into those clips, the complicated ones are the front rear clips, 2 of them you put together 2 clips.
here’s the link
https://www.ebay.com/itm/353955900462?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=na-x67ryrr2&sssrc=2349624&ssuid=aogoL4vfSOG&var=&widget_ver=artemis&media=COPY
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
