I'm looking for a compact 5 gallon sized jerry can that fits well under the bed rail area on the inside of the box. Essentially something that takes up less floor space on the bed of the box and tuck in nicely to the side so it's out of the way. I've seen quite a few that are narrower and taller than a traditional container, I'm sure that style will work, but just curious if there are any specific ones others have used that fit well.
Wish they'd just put larger tanks on these trucks so I didn't need this, but when pulling a trailer having an extra 5 gallons is some nice peace of mind.
Thanks for the help!
Hello. I purchased a frontrunner (two) jerry can holder (SKU: JCHO014)  My jerry cans were purchased from jerrycan.com (Gelg).
I simply bolted the tray onto the bed of my truck.
You will have issues with the GMC/Chevy fuel cap/entry as there is an inner metal flap which is hard to keep open. The jerrycan.com spout is rubber/plastic (Gelg), which does not do well. I modified a
VALPRO Long-Nose Flexible NATO Jerry Can Spout/Nozzle, Fits Wavian or VALPRO Euro Military Spec Cans (Olive Drab)
to fit the Gelg jerry can by modifying the gasket.
Cheers.
Truck should have come with the necessary tube/funnel to use when adding fuel from a portable container.
Filling the Tank With a Portable  Gas Can
If the vehicle runs out of fuel and must be filled from a portable gas can:
1. Locate the capless funnel adapter from inside the vehicle.
2. Insert and latch the funnel into the capless fuel system.
3. Remove and clean the funnel adapter and return to the storage location.
i use the plastic 5 gallon jug can from cyclegear. it comes with a long clear hose and a screw on cap, but havent found any special mounting system for the square jug, might have to weld up a bracket one day. i just bungie it down
1 hour ago, pokismoki said:
I like the RiskRacing jugs, but they clearly state they're not for gas or drinking water for that matter.
Quote
EZ Jugs are NOT portable fuel containers as described by ASTM, EPA, ARB and other official agencies. NOT SOLD FOR OR TO BE USED AS A PORTABLE FUEL CONTAINER. Your use of utility jugs as fuel containers or gas cans may violate the law of your state. Please check your own state law for the legal requirements pertaining to the use of these utility jugs and gas cans. Intended uses include storage and transport of feed, water, attractants, fluids and other outdoor products. Additional uses include transport, storage, and proper disposal of automotive and construction fluids such as antifreeze, engine oil, gear oils, hydraulic fluid, and transmission fluid. NOT INTENDED FOR DRINKING WATER STORAGE
That being said, I'm curious if anyone is actually using them for transporting fuel? I'd love to have a 5 gal one for when I go trekking through the mountains. Or even just carrying gas for my lawnmowers...
i use mine all the time when traveling over 400 miles, it really makes the trip feel safer with that little bit of insurance, considering new trucks these days only hold 21-25 gals.  its a must have if you run e85 with poor mpg range.
You can thank the great state of California for that.  The breather wouldn't be legal.  I'm sure if you talked to Risk in person, they'd give you a little wink.
Prefer the german jerry cans with the long spout.  The little 2.6 gallons cans are handy too, you might consider a pair of them instead depending on how you plan to arrange the bed.
  • 1 month later...
The only thing that worries me with the rotopax is I would want to make sure the fuel module rested it's weight on the bed, not by their hangers, not sure how well these aluminum beds walls will take 20-35lbs bouncing around flexing the bed sides.   Probably not a big deal if you're not off roading but there was recently an article where a bed mounted spare tire on a ford cracked the bed walls on both sides (two mounted tires).
Unfortunately due to NHTSA it's basically impossible for companies to manufacturer gasoline replacement tanks here (diesel only) that automatically feed into the factory tank.  Similar reasons are probably why some containers that might work perfectly fine for fuel will have disclaimers saying not to use them for fuel.
You can do a gasoline transfer tank in the bed that isn't connected to the factory fuel system, Titan I think makes a couple that also double as a truck tool box.   There's also the Titan 15 gal sidekick option that sits from one wheelwell going forward, but depending on the truck it may not fit under a tonneau cover.
https://titanfueltanks.com/titan-sidekick-15-gal-portable-liquid-tank-5040015
