87 still at $5.49 this morning. Reportedly, the WH offered Iran cash today to keep calm in the newly-developing scuffle with Israel. Iran said no. So I guess we all get to pay for this war out of our own pockets for even longer. This country has become so weak it's embarrassing.
Edited by Atlas
  • Haha 1
4 minutes ago, KARNUT said:
What happened to your $2.00 gas? Promises made, promises broken...
You are so ate up with TDS you can see anything positive. Any money Iran receives will be by releasing their own only if they comply. At least try not to be fake news.
  • Haha 1
That's funny because they were offered cash today to chill on the Israel thing. This admin is getting played like a fiddle and Iran knows it. It's absolutely embarrassing to witness.
We're going to lose the Iran deal and it's all Jeannie's fault. However, the day is not over. But this will be the 39th time it's been announced a deal is impending.
They’ll be a deal. Maybe the fifth level of the supreme leader. But a deal is going to happen.
Gas will be $2.00 tomorrow, then, right?? It’s all over now, and we can put high gas prices behind us?
Gas dropped a whopping $0.03 to $5.46 for regular this morning.
I wonder why the deal isn't a deal. It's a concept of a deal to occur sometime over the next 60 days. So far Iran says the Strait will not be "free", and still no nuclear concessions have been agreed to. So basically we begged them to relent in exchange for cash, with a likelihood we'll give away the farm in said "deal".
Market Manipulation Monday?
Taco Tuesday is always the next day.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
