The cover to my driver-side taillight is broken. Is there anywhere that sells just the cover or do I have to buy the whole light?
2019 GMC Sierra Denali
How odd, my neighbor has a 2019 Sierra Denali and I saw that his right LED taillight was broken so I informed him. He said he was aware of it, has been holding it off since it's $900 to fix it!
Do you just have to order it from the dealership? I have been trying to find a third party site for them but I can't find anything since mine has the LED lights.
You could also try looking at wrecking yards.
Try this part number 84565921
Schram Auto Parts in Michigan is a partner with GM for stripping and selling parts for damaged vehicles. I'm not sure what the deal is but they get tons of almost no to low mile vehicles that I'm guessing were damaged in shipping or were some test vehicle but they have LOTS of parts. They can be found on ebay but I got a heck of a deal on a seat when I went directly through them and I'm in Michigan so they cut me a deal since they didn't have to pack and ship the seat I bought. They even sent it for free to their shop that was about an hour from me vs the 2 1/2 hours to their main shop.
  • Thanks 1
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
