Hi All -
I know there’s a “spontaneous tailgate opening” thread but I haven’t found much info on this problem so here it goes…..
I have a situation where the tailgate won’t open (reliably) with the button on the tailgate.  If I push it enough times it finally opens.  The key fob as well as the button in the cab work fine.  Some info found online suggested maybe a switch.  For $17, I gave it a shot - no go.  It’s not at the dealer and, of course, they’re insisting on changing the switch again.
My experience in electronics says this is likely not a physical switch (or even wiring) issue.  The randomness of when or if it opens screams software or something “computer”/BCM.  I thought maybe the truck couldn’t sense the fob reliably in my pocket.  However, the “step release” button works reliably.
Any thoughts / ideas?  Dealer has had the truck for a week and no progress.
Thanks.
Dealer couldn't find the issue and is order (another) switch.  I'm surprised nobody else has had this problem here.  I'll respond once/if they find the culprit.
When you press the switch on the tailgate, can you hear the lock actuating? I found on mine, I have to slightly pull on the top handle / depression with my fingers as I push the button with my thumb and it opens normally. If I just simply push the switch, it's 50/50 if the tailgate will drop due to you're actually pushing the tailgate closed as you push the button...
I always hear the actuation but do not always get the tailgate to drop.   Eventually it does but I am wondering is there a manual tailgat latch override built in or possible mod.   When this truck has seen better days I want to still be opening the tailgate.  Also can the tailgate be opened with a dead battery?
jim
Edited by Maninthesea
8 minutes ago, Maninthesea said:
There is a provision for manually opening the tailgate behind a panel on the inside surface of the tailgate, so you could eventually get it open, but it’s not quick to use it.  Quickest way in the case of a dead battery would be to connect another 12v source.
Edited by Another JR
If you hear the actuation, the electric release mechanism needs lube. I would hear the clicking, but the gate would not open. Cleaning and lubing the locking mechanism got it working.
Anyone else have where you don't press the button hard enough and the tailgate won't release, but the fuel pump primes for some reason?
subscribing.... I have this with my '19 and dealer fix before. It's out of warranty, it sometimes opens after unlocking from inside or key fob 3-5 times. And sometimes it doesn't open and I just barely pull on it and it releases. Sounds more mechanically on my end is the problem where it's not disengaging.
I may try some lube and see if that works.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 1,224 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses more gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
