Today while towing my travel trailer with my 2022 chevy 1500 lt duramax, I got this message display on the dashboard (dic). Warning vehicle/trailer weight may exceed combined gross vehicle weight rating. Any idea what cause this warning message to display? I know the weight of the truck and trailer are way below the gcwr, same for the tongue weight. Thanks for your input.
This is certainly not what we like to hear, jowatt.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 Chevy 1500 LT Duramax. To do so, please send an email to [email protected] with ATTN: jowatt/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 10 months later...
I get the same message on my dash information center. I went to the scale and noticed I still had 2500 lbs before I hit the 15,000 GCWR. I also have a 2022 Silverado LT Crew Cab with he 5.3 engine. I have pictures of my weight at the scale with trailer and my information plate from the door of the truck. In case you have issues I will list my weights below:
Steer Axle: 3200 LB
Drive Axle: 3240 LB
Trailer Axle: 6060 LB
Gross Weight: 12500
My information plate states:
GAWR FRT 3800 LBS
GAWR RR 3800 LBS
GCWR 15000 LBS
Any answers on why this is happening? I will also email you the information.
Do you guys have a leveling suspension out back by chance?  The computer knows it should squat so much at such weight and may be the case.  TFL Truck saw this message but I do not remember if it was for GM pickups.  We're still running leaf springs and regular shocks right?
I wonder if it sensed being ''close'' to the limit in GM's mind to cover their butts, so it set the warning. Lots of folks towing over their head so it may default to an early warning for the ''average'' owner, not experienced folks who actually scaled their rig.
I'm wondering how system figures this out. Calculates throttle input, road speed, what gear it's in and factors all of that together?
Edited by repairman54
I got the same message with my 2023 Silverado 1500 with the 6.2 and my GVWR is 15000 and the total weight of what I'm towing plus the truck cargo and passengers is 13200.
I also received this message on my 2022.5 GMC 1500 with the 2.7.  I know for certain my trailer is not over gross with the weight of the truck. I didn’t receive this type of message until a recent technical update was done. I’m assuming when I last took my truck in for a recall fix. At that point they did an update to the trailer brake that previously was not working. I typically get the code when accelerating, such as from a stop sign at an incline or when the wind is dragging, or when on the interstate even at lower speeds.
I am very concerned this is to void a future warranty claim. The very reason I purchase new vehicles.
I certainly follow the manufacturer guidelines such as higher octane gasoline but I’m definitely concerned that GM is looking for an excuse.
Steer Axle: 3200 LB
Drive Axle: 3240 LB
Gross Weight: 12500
GAWR FRT 3800 LBS
GAWR RR 3800 LBS
GCWR 15000 LBS
This is certainly not what we like to hear, CKC.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: CKC/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
www.gm.com
Traded for a '23 which has this feature, so thought I'd look up what the manual says about it.
(I haven't towed yet...)
Gross Combined Weight (GCW) Alert
If equipped, the GCW Alert can display a message in the Driver Information Center (DIC), indicating that the estimated
combined weight of the vehicle and trailer may exceed the vehicle’s GCWR, under certain circumstances. See “Gross Combined Weight Rating” above.
The vehicle does not actually measure the loaded weight of your vehicle or trailer.
It uses vehicle data to estimate these weights after you begin a trip.
The alert will not activate unless:
. The feature is turned on in the trailering application. See Trailering App pg 321.
. The vehicle-trailer combination have been used enough together for the software to estimate the combined vehicle and trailer weight.
. The estimated weight could exceed the vehicle’s maximum GCWR.
and from the Trailering App section (app info starts on page 321, this is from pg 327)
I Just bought a ‘22 Silverado Refresh 1500. Before installing air springs I towed the same trailer with the same weight (well under GCVW and conventional trailer weight) and had no alerts. Installed air springs and now I get the warning (conditions unchanged except air springs). I am assuming that they have something to do with the calculations the computer is making. 🤷‍♂️
    ncleg
    ncleg
  • Who's Online   7 Members, 0 Anonymous, 744 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
