So, I have a '22 CC LT and the only thing it doesn't have that I really wish it did is a bed view camera. I've searched several forums to see if it could be added, and up to this point, all efforts seem futile. Between modules and reprogramming to get the camera to show on the head unit, every lead ended up dead. We just got a new truck on the lot that has the bed view camera display in a small screen in the rear view mirror. And it is activated by a button on the camera; seemingly independent of any other module. I pulled the part numbers using that specific VIN:
85510310 Mirror
84601056 CHMSL with Camera
84859040 Camera Wiring
Does anybody have more knowledge that I do that my be able to discern if I bought these parts and put them on my truck, they would basically be plug and play. I can get pictures of the truck that has it and provide the VIN if that would help...Thoughts???
I have a 2020 and I remember a year or more ago I did come across a post somewhere that was talking about basically this exact setup, only it was mainly for the rear-view display and didn't really mention the bed view button.  The discussion then was that this is a separate system and all that was needed to make it work was the mirror, cable, and light with the camera.  There was NO programming involved.  Because the trucks were fairly new at the time, getting those parts were nearly impossible so the idea went away, but I'm in the same spot as you and really like the idea of a bed view like you are showing.
I had a 2021 2500 HD Denali that had a bed view camera, but it was accessed through the camera app and showed up on the in-dash display. I like the idea of a button on the mirror with the pic in pic display. It looks like it's much simpler to activate.
On 7/12/2022 at 10:21 AM, lsorah0001 said:
Pictures of said truck...
Just curious,  when the camera is not activated,  is the mirror a standard mirror?  I installed closed to the same setup but it was a rear view camera.  The camera points over the top of the bed and not down in your bed.  It was 100% plug in play.  You just had to buy the mirror, camera/center tail light and a cable.  The mirror plugged into a power connector in your head liner.
Most trucks already have the power connector.
the part list for rearview is below:
What you are doing does make sense is should be plug in play just as the above is all controlled by the mirror it self.
What chevy needs is a mirror that can switch between two camera, one for the bed and the second for rearview.
This will be an interesting thread to follow.
Edited by KTDanforth
@KTDanforth Yes, It's just a standard mirror without the screen on... I haven't went searching for the plugs yet, but gen5diy has a rear view camera setup for sale on their site. And the truck they installed it in didn't have the plugs from the factory. I did send them an email suggesting a kit for the bed view camera. We'll see if I get a response before I look for the plugs in my truck...
This is an interesting setup. All the bedview I've seen has been through the specific bedview camera and into the head unit, but this requires a video processing unit. I'm wondering if with chip shortages, they've switched to this setup.
It looks really similar to the way the Rear View Camera Mirror works. As far as I know, that setup is a new taillight assembly with the rear view camera (different then bed view), and that camera needs a Fakra extension cable which then plugs to the mirror itself, and the mirror gets power from a harness in the headliner. There are some good posts in the non-HD T1 forums on this. It appears it would be wired this way.
I believe there are three taillight assemblies. One is Rear view, one is bed view, and one has dual cameras.
This is an example of that setup and they have some videos showing the install procedure.... 2019-2022 Silverado or Sierra Factory OEM Backup Rear Camera LCD Mirro - Infotainment.com
I'm interested in this too. I like the mirror controlling it with a switch. When looking into a VIN with an OEM rear camera they have a video controller where mine does not. I have a 21 SLE. I have a new High Mount 3rd brake light with camera. P/N 84699124
Chris
any write up on installing this?
Edited by cwalsh
I was looking for the thread, I believe it is in the chevy 1500 mod section, but I attached the infortaintment video that has the walk thru.  The whole thing is plug in play, no programming.
(2) 2019-2021 Chevrolet Silverado / GMC Sierra Rear Camera LCD OEM Mirror - Easy Plug & Play Install! - Bing video
Buy the parts yourself and save the money.   All are pretty cheap, except the mirror, I was able to find a take off mirror for about $300.  the rest of the parts were less than $150, so all in was $450.
good luck
good luck
I installed mine this weekend. I ended up taking the camera from the 84487008 and put it in a bed view third brake light lens (84699124) and installed. Turned out nice. Just need to get the trim for the wiring around the mirror.
Chris
Chris
Did you get everything buttoned up? Do you have any pics of the final result or install?
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 987 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
