QR Code / RPO Code Deciphering
1st you have to SCAN the QR Code on the Drivers Door Jam and convert it to English (kind sorta lol)
I used both these 2 links to read ALL my RPO Codes
https://manualzz.com/doc/28236227/rpo-codes-and-descriptions
http://www.rpocodes.com/GM-RPO-codes/gmrpocodes0through4.html
and here is the online Owners Manual (2022)
https://cdn.dealereprocess.org/cdn/servicemanuals/gmc/2022-sierra2500hd.pdf
Neither of those lists hold all codes. I have a number which are not listed ('22 Sierra HD), in fact, after a lengthy search, I have yet to find a fully complete list.
Marv
Lots are not really 'regular production options' (RPO) but components.  The SPID label or QR code lists rpo and component info for service parts identification.  Some are just going to show components for the particular vehicle such as suspension components which can vary vehicle to vehicle depending the weights of options etc etc.
SPID - Service Parts Indentifation
Edited by elcamino
You can get a more complete list by having a (any) dealer print out the build sheet from for the vin.
From 2022 order guide:
RPO Codes - GMC Sierra/Denali 2500 HD
  A - H  I - P  Q - Z
Option
Code
Description
00G
Not Equipped with Heated Steering Wheel, see dealer for details
00V
Not Equipped with Heated or Ventilated Front Seats, see dealer for details
00Z
Not Equipped with Front and Rear Park Assist, see dealer for details
01U
Special Exterior Color
04O
Not Equipped with Driver and Front Passenger Ventilated Seat Cushion Blower Motor, see dealer for details
5H1
Key equipment, two additional keys for single key system
5JY
LPO, Tri-fold soft tonneau cover by Advantage, (dealer-installed)
5M7
Speedometer calibration, provisions
5N5
Rear Camera Kit
5VI
LPO, Cargo tie-down rings
5Y1
Seats, Driver and passenger front individual seatsDriver and passenger front individual seats derived from a 40-20-40 split bench seat with the 20% section removed. Also removes the USB port and auxiliary power outlet when (AZ3) bench seat is ordered. Does not include a floor console. All exposed floor area will remain untrimmed.
5Z4
Spare wheel, tire, carrier and lock delete
63G
LPO, GMC MultiPro tailgate Step Lights
8F2
Ornamentation, delete
8S3
Back-up alarm, 97 decibels
8X8
Label, fasten seat belts
9B9
Governor, electronic speed sensor set to 70 MPH
9C2
Governor, electronic speed sensor set to 65 MPH
9D7
Governor, electronic speed sensor set to 75 MPH
9J4
Bumper, rear, delete
9L3
Spare tire delete
9L7
Upfitter switch kit
9M4
Decal and name plate delete, tailgate
9N2
GVWR, 10,050 lbs. (4559 kg)
9R1
Decal delete, Pickup bed
9V5
Paints, solid, Woodland Green
9W3
Paints, solid, Wheatland Yellow
9W4
Paints, solid, Tangier Orange
A2S
Seat adjuster, driver 4-way manual
A2X
Seat adjuster, driver 10-way power including lumbar
A45
Driver memory
A48
Window, power, rear sliding
A50
Seats, front bucket
A60
Tailgate, locking
A68
Seat, rear 60/40 folding bench
A6Q
Windows, manual
A7E
Seat adjuster, passenger 4-way manual
A7K
Seat adjuster, passenger 10-way power including lumbar
AAK
LPO, All-weather floor liners, 1st and 2nd rows
AE7
Seats, front 40/20/40 split-bench
AED
Window, power front
AEF
Window, power
AEQ
Windows, power
AKO
Glass, deep-tinted
AKP
Glass, solar absorbing
AQQ
Remote Keyless Entry
ATH
Keyless Open and Start
AU3
Door locks, power
AXG
Windows, power
AY0
Airbags, Dual-stage frontal airbags for driver and front outboard passenger; Seat-mounted side-impact airbags for driver and front outboard passenger; Head-curtain airbags for front and rear outboard seating positions; Includes front outboard Passenger Sensing System for frontal outboard passenger airbag
AZ3
B1J
Wheelhouse liners, rear
B30
Floor covering, color-keyed carpeting
B32
Floor mats, rubberized-vinyl front
B33
Floor mats, rubberized-vinyl rear
B34
Floor mats, carpeted front
B35
Floor mats, carpeted rear
B3L
Assist steps
B59
Remote Start Package
BG9
Floor covering, rubberized-vinyl
BHP
Winter Grille Cover
BKE
Premium Floor Liners with removable carpet insert, rear
BKF
Premium Floor Liners with removable carpet insert, front
BRS
Assist steps
BTV
Remote vehicle starter system
BVQ
Assist steps, chromed
BWN
CornerStep, rear bumper
C49
Defogger, rear-window
C4M
GVWR, 9900 lbs. (4490 kg)
C59
Air vents, rear
C67
Air conditioning, single-zone
C7A
Lowered GVWR, 10,000 lbs. (4536 kg)
C7E
GVWR, 11,000 lbs. (4990 kg)
C7G
GVWR, 10,500 lbs. (4763 kg)
CF5
Sunroof, power
CGN
Bed Liner, Spray-on
CJ2
Air conditioning, dual-zone automatic climate control
CKM
GVWR, 10,960 lbs. (4961 kg)
CMT
Gooseneck / 5th Wheel Package
CTT
Hitch Guidance
CWM
Technology Package
D07
Center Console, floor
D31
Mirror, inside rearview
D72
Door handles, Black
D75
Door handles, body-color
DBG
Mirrors, outside power-adjustable vertical trailering with heated upper glass, lower convex mirrors, integrated turn signals, manual folding/extending (extends 3.31" [84.25mm])
DD8
Mirror, inside rearview auto-dimming
DLN
Mirrors, outside heated power-adjustable
DP6
Mirror caps
DP9
Mirror caps, chrome
DRC
Mirror
DRZ
Rear Camera Mirror
DUD
Mirrors, outside high-visibility vertical trailering, lower convex mirrors, manual-folding/extending (extends 3.31" [84.25mm]), molded in Black
DWI
Mirrors, outside power-adjustable vertical trailering with heated and auto-dimming upper glass, lower convex mirrors, turn signal indicators, puddle lamps, perimeter lighting, auxiliary lighting, power folding/manual extending (extends 3.31" [84.25mm])
DZC
Mirrors, outside power-adjustable vertical trailering with heated and auto-dimming upper glass, (driver and passenger), lower convex mirrors, turn signal indicators, puddle lamps, perimeter lighting, auxiliary lighting, power folding/extending (extends 3.31" [84.25mm])
E20
Door handles, chrome
E63
Pickup bed
F60
Heavy Duty Front Spring/Camper Package
FE9
Emissions, Federal requirements
FHS
E85 FlexFuel capable
G80
Auto-locking rear differential
GT4
Rear axle, 3.73 ratio
GU6
Rear axle, 3.42 ratio
HS1
Safety Alert Seat
IOR
Audio system, GMC Infotainment System with 7" diagonal color touch-screen
IOR
Audio system, GMC Infotainment System with 8" diagonal color touch-screen
IOS
Audio system, Premium GMC Infotainment System with 8" diagonal color touch-screen
IOT
Audio system, Premium GMC Infotainment System with Navigation and 8" diagonal color touch-screen
J61
Brakes, 4-wheel antilock, 4-wheel disc
JBP
Brake lining wear indicator
JFG
GVWR, 10,200 lbs. (4627 kg)
JFH
GVWR, 10,300 lbs. (4672 kg)
JFI
GVWR, 10,400 lbs. (4717 kg)
JFK
GVWR, 10,700 lbs. (4854 kg)
JFL
GVWR, 10,800 lbs. (4899 kg)
JFM
GVWR, 10,900 lbs. (4944 kg)
JFN
GVWR, 11,100 lbs. (5035 kg)
JFO
GVWR, 11,200 lbs. (5080 kg)
JFP
GVWR, 11,300 lbs. (5126 kg)
JGA
GVWR, 10,150 lbs. (4604 kg)
JGB
GVWR, 10,250 lbs. (4649 kg)
JGC
GVWR, 10,350 lbs. (4695 kg)
JGD
GVWR, 10,450 lbs. (4740 kg)
JGE
GVWR, 10,550 lbs. (4785 kg)
JGF
GVWR, 10,650 lbs. (4831 kg)
JGG
GVWR, 10,750 lbs. (4876 kg)
JGH
GVWR, 10,850 lbs. (4921 kg)
JGJ
GVWR, 11,050 lbs. (5012 kg)
JGK
GVWR, 11,150 lbs. (5058 kg)
JGL
GVWR, 11,350 lbs. (5148 kg)
JGM
GVWR, 11,450 lbs. (5194 kg)
JGN
GVWR, 11,550 lbs. (5239 kg)
JHD
Hill Descent Control
JL1
Trailer brake controller, integrated
JSE
Denali Black Diamond Edition
K05
Engine block heater
K1O
Air filtration monitoring
K34
Cruise control
K40
Exhaust brake
K47
Air filter, heavy-duty
K4B
Battery, auxiliary
K4C
Wireless Charging
KA1
Seating, heated driver and front outboard passenger
KA6
Seats, heated second row
KC4
Cooling, external engine oil cooler
KC5
Power outlet, front auxiliary
KC9
Power outlet
KHF
Alternators, dual, 220-amps primary, 170-amps auxiliary
KI3
Steering wheel, heated
KI4
Power outlet
KNP
Cooling, auxiliary external transmission oil cooler
KPA
Power outlet, rear auxiliary, 12-volt
KQV
Seats, ventilated driver and front passenger
KW5
Alternator, 220 amps
KW7
Alternator, 170 amps
L5P
Engine, Duramax 6.6L Turbo-Diesel V8, B20-Diesel compatible
L8T
Engine, 6.6L V8
MCR
USB Ports (Instrument Panel with bench seat)
MCR
USB Ports (Inside Console with bucket seats)
MCZ
USB ports
MGM
Transmission, Allison 10-Speed automatic
MGU
Transmission, Allison 10-Speed automatic with integrated Power Take-Off (PTO)
MYD
Transmission, 6-speed automatic, heavy-duty
N06
Steering column, lock control
N33
Steering column, Tilt-Wheel
N37
Steering column, manual Tilt-Wheel
NB8
Emissions override, California
NB9
Emissions override, state-specific
NC7
Emissions override, Federal
NE1
Emissions, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington state requirements
NK5
Steering wheel, urethane
NP5
Steering wheel, leather-wrapped
NQF
Transfer case, two-speed, electronic shift with push button controls
NQH
Transfer case, two-speed active
NV8
Steering, Digital Variable Steering Assist
NZZ
Skid Plates
P0G
GM Commercial Link - 1 year of Service
P0H
GM Commercial Link - 2 years of Service
P0I
GM Commercial Link - 3 years of Service
P0J
OnStar Additional 21 months of OnStar Fleet Safety and Security
P0K
OnStar Additional 33 months of OnStar Fleet Safety and Security
P0L
OnStar Additional 45 months of OnStar Fleet Safety and Security
P0M
OnStar Additional 21 months of OnStar Fleet Remote Access
P0N
OnStar Additional 33 months of OnStar Fleet Remote Access
P0O
OnStar Additional 45 months of OnStar Fleet Remote Access
P1R
OnStar Additional 9 months of OnStar Assurance for Tier3 Fleets
P1S
OnStar Additional 21 months of OnStar Assurance for Tier3 Fleets
P1T
OnStar Additional 33 months of OnStar Assurance for Tier3 Fleets
P1U
OnStar Additional 45 months of OnStar Assurance for Tier3 Fleets
PCI
Convenience Package
PCQ
SLE Convenience Package
PCY
SLT Convenience Package
PDB
SLT Premium Package
PDC
Texas SLT Premium Package
PDG
AT4 Premium Plus Package
PDH
LPO, GMC Protection Package
PDJ
Driver Alert Package II
PDL
LPO, Cargo Convenience Package
PDO
AT4 Preferred Package
PDQ
Preferred Package
PDR
LPO, Assist step and floor liner package
PDU
SLE Value Package
PDV
LPO, MultiPro Audio System by Kicker
PDY
SLT Preferred Package
PEC
Denali Ultimate Package
PQA
1SA Driver Alert Package I
PQB
PR6
SiriusXM Radio Additional 9 months of the SiriusXM All Access Package.
PR7
SiriusXM Radio Additional 21 months of the SiriusXM All Access Package.
PR8
SiriusXM Radio Additional 33 months of the SiriusXM All Access Package.
PTO
Power Take-Off
PTT
Trailer Tire Pressure Monitor Sensors
PXD
Wheels, 18" (45.7 cm) machined aluminum wheel with Dark Grey metallic accents
PYN
Wheels, 17" (43.2 cm) painted steel, Silver
PYQ
Wheels, 17" (43.2 cm) machined aluminum
PYT
Wheels, 18" (45.7 cm) 8-spoke painted steel, Silver
PYU
Wheels, 20" (50.8 cm) machined aluminum with high gloss Black accents
PZ8
Hitch Guidance with Hitch View
Q7Q
Wheels, 20" transit aluminum wheels for LPO 20" wheels and tires
Q7R
Wheels, 20" (50.8 cm) machined aluminum wheel with bright Silver accents
QF6
Tires, LT275/70R18E all-terrain, blackwall
QF9
Tires, LT275/65R20 all-terrain, blackwall
QG3
Tires, LT275/70R18, mud-terrain, blackwall
QHQ
Tires, LT245/75R17E all-season, blackwall
QK1
Tailgate, standard
QK2
Tailgate, GMC MultiPro Tailgate
QT2
Tailgate, gate function manual
QT5
Tailgate, gate function manual with EZ Lift, includes power lock and release
QXT
Tires, LT265/70R17E all-terrain, blackwall
R7O
Seat, Cloth Rear with Storage Package, 60/40 folding bench
R8R
Delete: Spray-on bedliner
R9M
3 years of OnStar & Connected Services Plan, see onstar.com for information
RFX
X31 Off-Road and Protection Package
RFZ
Not Equipped with Rear Wheelhouse Liners, see dealer for details
RGE
1SA Safety Confidence Package
RGJ
Not Equipped with Heated Second Row Outboard Seats, see dealer for details
RGL
LPO, Denali Illumination Package
RIA
RN2
LPO, Illuminated front GMC emblem
RQA
Wheels, 20" (50.8 cm) multi-dimensional Polished aluminum
RSR
Rear Seat Reminder
RTJ
Wheels, 20" (50.8 cm) high gloss Black painted aluminum
RVQ
LPO, Black tubular assist steps, 6" rectangular
RVS
LPO, Black tubular assist steps, 4" round
RW9
LPO, Bedside storage boxes, full-length
S0M
LPO, Denali Illuminated door sills
S0P
LPO, Console Insert Organizer Tray
S1O
LPO, Console-Mounted Safe
S3I
LPO, GMC Illuminated puddle lamp emblem
S6L
LPO, Sport Step, Black
SAF
Tire carrier lock
SBZ
LPO, Sport Pedal Cover Kit
SF6
LPO, Body color wheel arch moldings
SFW
Back-up alarm calibration
SHH
LPO, 20" (50.8 cm) High gloss Black painted wheels
SHL
LPO, 20" (50.8 cm) Chrome aluminum wheels
SKW
LPO, 20" (50.8 cm) multi-dimensional Chrome aluminum wheels
SKX
LPO, 20" (50.8 cm) high gloss Black aluminum wheels with machined accents
SNO
LPO, Hitch Package, Gooseneck ball and chain tiedown kit with case
SNR
Seat, Up-level Rear with Storage Package, 60/40 folding bench
SQ9
LPO, 20" (50.8 cm) Machined Aluminum Bolt Pattern with High Gloss Black Accents wheels
T3U
Fog lamps
TCE
Ship Thru, for Orders with (CGN) Spray-on Bedliner, Produced in Flint Assembly and shipped to Auto Truck Group, Roanoke, IN and returned to Ft. Wayne Assembly for shipping to final destination
TCH
Ship Thru, for Orders with (CGN) Spray-on Bedliner, Produced in Flint Assembly and shipped to Reading Truck Equipment, Pontiac, MI and returned to Flint Assembly for shipping to final destination
TCL
Ship Thru, Produced in Flint Assembly and shipped to Kerr Industries, Warren, MI. Returned to Flint Assembly for shipping to final destination
TDE
Ship Thru, Produced in Flint Assembly and shipped to Monroe Truck Equipment, MI, Then to TK Services, AK for shipping to final destination
TDM
Teen Driver
TQ5
IntelliBeam
TRO
LPO, Auxiliary Trailer Camera, wired
TVY
Ship Thru, Produced and shipped to Anchorage VDC then to TK Services and returned to Anchorage VDC for shipping to final destination
TZS
Ship Thru, Produced in Flint Assembly and shipped to Alt. Fuel Innovations LLC, Kansas City, MO. Returned to Fairfax Assembly for shipping to final destination
U01
Lamps, Smoked Amber roof marker
U1D
Trailering App
U2K
SiriusXM Radio
U95
Audio system feature, 2-speakers
UD5
UDC
Driver Information Center
UDD
Driver Information Center, 4.2" diagonal
UE1
OnStar and GMC Connected Services capable
UE4
Following Distance Indicator
UEU
Forward Collision Alert
UF2
LED Cargo Area Lighting
UF3
High idle switch
UFG
Rear Cross Traffic Alert
UFL
Lane Departure Warning
UG1
Universal Home Remote
UGA
Recovery hooks
UHS
Driver Information Center, enhanced, 8" diagonal multicolor digital display
UHY
Automatic Emergency Braking
UJM
Tire Pressure Monitoring System
UK3
Steering wheel audio controls
UKC
Lane Change Alert with Side Blind Zone Alert
UQA
Bose Sound System, premium 7-speaker system
UQF
Audio system feature, 6-speaker system
USS
USB ports, dual
UTJ
Theft-deterrent system
UV6
Multicolor 15" Diagonal Head-Up Display
UVB
HD Rear Vision Camera
UVC
Rear Vision Camera
UVN
Bed View Camera
UVO
Bed View Camera
UVS
HD Surround Vision with Two Trailer View Camera Provisions
UY2
Trailering wiring provisions
V46
Bumper, front chrome
V76
Recovery hooks, front, frame-mounted
VB5
Bumper, front, body-color
VBJ
LPO, Rear underseat storage, composite storage bin
VCB
Ship Thru, Produced in Flint Assembly and shipped to Monroe Truck Equipment in Flint. Returned to Flint Assembly for shipping to final destination.
VDB
Ship Thru, Produced in Flint Assembly and shipped to Empire Emergency Apparatus, Niagara Falls, NY. Returned to Flint Assembly for shipping to final destination.
VDF
Ship Thru, Produced in Flint Assembly and shipped to ECO Vehicle Systems, Union City, IN. Returned to FT. Wayne Assembly for shipping to final destination.
VEW
Ship Thru, Produced in Flint Assembly and shipped to Canfield Equipment in Warren, MI. Returned to Lansing Delta for shipping to final destination.
VFW
Ship Thru, Produced in Flint Assembly and shipped to NBC Truck Equipment Roseville, MI. Returned to Flint Assembly for shipping to final destination.
VHR
Ship Thru, Produced in Flint Assembly and shipped to Reading Equipment and Distribution Pontiac, MI. Returned to Lansing Delta for shipping to final destination.
VJH
Bumper, rear chrome
VK3
License plate kit, front
VLQ
VOZ
LPO, Hard-folding tonneau cover
VQK
LPO, Front and Rear Molded Splash Guards
VQO
LPO, Black assist step
VQZ
LPO, Polished exhaust tip
VSH
Ship Thru, for Orders with (CGN) Spray-on Bedliner, Produced in Flint Assembly and shipped to Monroe Truck Equipment, Flint, MI and returned to Flint Assembly for shipping to final destination
VSX
Trailering Information Label
VT5
Bumper, rear body-color
VTV
Ship Thru, for Orders with (CGN) Spray-on Bedliner, Produced in Flint Assembly and shipped to Knapheide Truck Equipment, Flint, MI and returned to Flint Assembly for shipping to final destination
VUD
Ship Thru, Produced in Flint Assembly and shipped to Knapheide Truck Equipment in Flint, MI. Returned to Flint Assembly for shipping to final destination.
VUI
Ship Thru, Produced in Flint Assembly and shipped to Auto Truck Group, Roanoke, IN and Returned to Ft. Wayne Assembly for shipping to final destination
VV4
Wi-Fi Hotspot capable
VXH
LPO, Assist steps, chromed tubular
VXJ
VXW
LPO, Off-Road High Clearance Steps, (dealer-installed)
VYU
Snow Plow Prep/Camper Package
X31
X31 Off-Road Package
YF5
Emissions, California state requirements
Z6A
Gooseneck / 5th Wheel Prep Package
Z82
Trailering Package
Z85
Suspension Package
ZHQ
Tire, spare LT245/75R17E all-season, blackwall
ZL6
ProGrade Trailering System
ZW9
Pickup bed, delete
ZXT
Tire, spare LT265/70R17E all-terrain, blackwall
ZYG
Tire, spare LT275/70R18 all-terrain, blackwall
  A - H  I - P  Q - Z
Option
Code
Description
00G
00V
00Z
01U
04O
5H1
5JY
5M7
5N5
Rear Camera Kit
5VI
5Y1
5Z4
63G
8F2
8S3
8X8
9B9
9C2
9D7
9J4
9L3
Spare tire delete
9L7
Upfitter switch kit
9M4
9N2
9R1
9V5
9W3
9W4
A2S
A2X
A45
Driver memory
A48
A50
Seats, front bucket
A60
Tailgate, locking
A68
A6Q
Windows, manual
A7E
A7K
AAK
AE7
AED
Window, power front
AEF
Window, power
AEQ
Windows, power
AKO
Glass, deep-tinted
AKP
AQQ
ATH
AU3
Door locks, power
AXG
Windows, power
AY0
AZ3
B1J
B30
B32
B33
B34
B35
B3L
Assist steps
B59
BG9
BHP
Winter Grille Cover
BKE
BKF
BRS
Assist steps
BTV
BVQ
BWN
C49
C4M
C59
Air vents, rear
C67
C7A
C7E
C7G
CF5
Sunroof, power
CGN
Bed Liner, Spray-on
CJ2
CKM
CMT
CTT
Hitch Guidance
CWM
Technology Package
D07
D31
D72
Door handles, Black
D75
DBG
DD8
DLN
DP6
Mirror caps
DP9
Mirror caps, chrome
DRC
Mirror
DRZ
Rear Camera Mirror
DUD
DWI
DZC
E20
E63
Pickup bed
F60
FE9
FHS
G80
GT4
GU6
HS1
Safety Alert Seat
IOR
IOR
IOS
IOT
J61
JBP
JFG
JFH
JFI
JFK
JFL
JFM
JFN
JFO
JFP
JGA
JGB
JGC
JGD
JGE
JGF
JGG
JGH
JGJ
JGK
JGL
JGM
JGN
JHD
JL1
JSE
K05
Engine block heater
K1O
K34
Cruise control
K40
Exhaust brake
K47
K4B
Battery, auxiliary
K4C
Wireless Charging
KA1
KA6
KC4
KC5
KC9
Power outlet
KHF
KI3
KI4
Power outlet
KNP
KPA
KQV
KW5
KW7
L5P
L8T
Engine, 6.6L V8
MCR
MCR
MCZ
USB ports
MGM
MGU
MYD
N06
N33
N37
NB8
NB9
NC7
NE1
NK5
NP5
NQF
NQH
NV8
NZZ
Skid Plates
P0G
P0H
P0I
P0J
P0K
P0L
P0M
P0N
P0O
P1R
P1S
P1T
P1U
PCI
Convenience Package
PCQ
PCY
PDB
SLT Premium Package
PDC
PDG
PDH
PDJ
PDL
PDO
PDQ
Preferred Package
PDR
PDU
SLE Value Package
PDV
PDY
PEC
PQA
PQB
PR6
PR7
PR8
PTO
Power Take-Off
PTT
PXD
PYN
PYQ
PYT
PYU
PZ8
Q7Q
Q7R
QF6
QF9
QG3
QHQ
QK1
Tailgate, standard
QK2
QT2
QT5
QXT
R7O
R8R
R9M
RFX
RFZ
RGE
RGJ
RGL
RIA
RN2
RQA
RSR
Rear Seat Reminder
RTJ
RVQ
RVS
RW9
S0M
S0P
S1O
S3I
S6L
SAF
Tire carrier lock
SBZ
SF6
SFW
SHH
SHL
SKW
SKX
SNO
SNR
SQ9
T3U
Fog lamps
TCE
TCH
TCL
TDE
TDM
Teen Driver
TQ5
IntelliBeam
TRO
TVY
TZS
U01
U1D
Trailering App
U2K
SiriusXM Radio
U95
UD5
UDC
UDD
UE1
UE4
UEU
UF2
UF3
High idle switch
UFG
UFL
UG1
UGA
Recovery hooks
UHS
UHY
UJM
UK3
UKC
UQA
UQF
USS
USB ports, dual
UTJ
UV6
UVB
UVC
Rear Vision Camera
UVN
Bed View Camera
UVO
Bed View Camera
UVS
UY2
V46
V76
VB5
VBJ
VCB
VDB
VDF
VEW
VFW
VHR
VJH
Bumper, rear chrome
VK3
VLQ
VOZ
VQK
VQO
VQZ
VSH
VSX
VT5
VTV
VUD
VUI
VV4
VXH
VXJ
VXW
VYU
X31
YF5
Z6A
Z82
Trailering Package
Z85
Suspension Package
ZHQ
ZL6
ZW9
Pickup bed, delete
ZXT
ZYG
Thank you. I was actually looking for this website online at https://writinguniverse.com/free-essay-examples/power/ because I wanted to read essay examples for free, and while doing so, I came across it.
Thank you :)
Edited by RobertAMorrow
Caution using the above list for other model years.
Items 'included' with a given RPO code can and do change.
  • 5 weeks later...
  A - H  I - P  Q - Z
Option
Code
Description
00G
00V
00Z
01U
04O
5H1
5JY
5M7
5N5
Rear Camera Kit
5VI
5Y1
5Z4
63G
8F2
8S3
8X8
9B9
9C2
9D7
9J4
9L3
Spare tire delete
9L7
Upfitter switch kit
9M4
9N2
9R1
9V5
9W3
9W4
A2S
A2X
A45
Driver memory
A48
A50
Seats, front bucket
A60
Tailgate, locking
A68
A6Q
Windows, manual
A7E
A7K
AAK
AE7
AED
Window, power front
AEF
Window, power
AEQ
Windows, power
AKO
Glass, deep-tinted
AKP
AQQ
ATH
AU3
Door locks, power
AXG
Windows, power
AY0
AZ3
B1J
B30
B32
B33
B34
B35
B3L
Assist steps
B59
BG9
BHP
Winter Grille Cover
BKE
BKF
BRS
Assist steps
BTV
BVQ
BWN
C49
C4M
C59
Air vents, rear
C67
C7A
C7E
C7G
CF5
Sunroof, power
CGN
Bed Liner, Spray-on
CJ2
CKM
CMT
CTT
Hitch Guidance
CWM
Technology Package
D07
D31
D72
Door handles, Black
D75
DBG
DD8
DLN
DP6
Mirror caps
DP9
Mirror caps, chrome
DRC
Mirror
DRZ
Rear Camera Mirror
DUD
DWI
DZC
E20
E63
Pickup bed
F60
FE9
FHS
G80
GT4
GU6
HS1
Safety Alert Seat
IOR
IOR
IOS
IOT
J61
JBP
JFG
JFH
JFI
JFK
JFL
JFM
JFN
JFO
JFP
JGA
JGB
JGC
JGD
JGE
JGF
JGG
JGH
JGJ
JGK
JGL
JGM
JGN
JHD
JL1
JSE
K05
Engine block heater
K1O
K34
Cruise control
K40
Exhaust brake
K47
K4B
Battery, auxiliary
K4C
Wireless Charging
KA1
KA6
KC4
KC5
KC9
Power outlet
KHF
KI3
KI4
Power outlet
KNP
KPA
KQV
KW5
KW7
L5P
L8T
Engine, 6.6L V8
MCR
MCR
MCZ
USB ports
MGM
MGU
MYD
N06
N33
N37
NB8
NB9
NC7
NE1
NK5
NP5
NQF
NQH
NV8
NZZ
Skid Plates
P0G
P0H
P0I
P0J
P0K
P0L
P0M
P0N
P0O
P1R
P1S
P1T
P1U
PCI
Convenience Package
PCQ
PCY
PDB
SLT Premium Package
PDC
PDG
PDH
PDJ
PDL
PDO
PDQ
Preferred Package
PDR
PDU
SLE Value Package
PDV
PDY
PEC
PQA
PQB
PR6
PR7
PR8
PTO
Power Take-Off
PTT
PXD
PYN
PYQ
PYT
PYU
PZ8
Q7Q
Q7R
QF6
QF9
QG3
QHQ
QK1
Tailgate, standard
QK2
QT2
QT5
QXT
R7O
R8R
R9M
RFX
RFZ
RGE
RGJ
RGL
RIA
RN2
RQA
RSR
Rear Seat Reminder
RTJ
RVQ
RVS
RW9
S0M
S0P
S1O
S3I
S6L
SAF
Tire carrier lock
SBZ
SF6
SFW
SHH
SHL
SKW
SKX
SNO
SNR
SQ9
T3U
Fog lamps
TCE
TCH
TCL
TDE
TDM
Teen Driver
TQ5
IntelliBeam
TRO
TVY
TZS
U01
U1D
Trailering App
U2K
SiriusXM Radio
U95
UD5
UDC
UDD
UE1
UE4
UEU
UF2
UF3
High idle switch
UFG
UFL
UG1
UGA
Recovery hooks
UHS
UHY
UJM
UK3
UKC
UQA
UQF
USS
USB ports, dual
UTJ
UV6
UVB
UVC
Rear Vision Camera
UVN
Bed View Camera
UVO
Bed View Camera
UVS
UY2
V46
V76
VB5
VBJ
VCB
VDB
VDF
VEW
VFW
VHR
VJH
Bumper, rear chrome
VK3
VLQ
VOZ
VQK
VQO
VQZ
VSH
VSX
VT5
VTV
VUD
VUI
VV4
VXH
VXJ
VXW
VYU
X31
YF5
Z6A
Z82
Trailering Package
Z85
Suspension Package
ZHQ
ZL6
ZW9
Pickup bed, delete
ZXT
ZYG
Spoiler
Thanks for the guide. It is really very helpful. I'm going to pursue a career in education after reading your story to see whether I encounter the similar issue. By the way, if you want assistance from qualified essay writers, go to https://letsgradeit.com/review/essaypro/ to locate them quickly. When it comes time for me to turn in my essay assignments before the deadline, I also seek assistance from their qualified essay writers.
Edited by EricMack
  A - H  I - P  Q - Z
Option
Code
Description
00G
00V
00Z
01U
04O
5H1
5JY
5M7
5N5
Rear Camera Kit
5VI
5Y1
5Z4
63G
8F2
8S3
8X8
9B9
9C2
9D7
9J4
9L3
Spare tire delete
9L7
Upfitter switch kit
9M4
9N2
9R1
9V5
9W3
9W4
A2S
A2X
A45
Driver memory
A48
A50
Seats, front bucket
A60
Tailgate, locking
A68
A6Q
Windows, manual
A7E
A7K
AAK
AE7
AED
Window, power front
AEF
Window, power
AEQ
Windows, power
AKO
Glass, deep-tinted
AKP
AQQ
ATH
AU3
Door locks, power
AXG
Windows, power
AY0
AZ3
B1J
B30
B32
B33
B34
B35
B3L
Assist steps
B59
BG9
BHP
Winter Grille Cover
BKE
BKF
BRS
Assist steps
BTV
BVQ
BWN
C49
C4M
C59
Air vents, rear
C67
C7A
C7E
C7G
CF5
Sunroof, power
CGN
Bed Liner, Spray-on
CJ2
CKM
CMT
CTT
Hitch Guidance
CWM
Technology Package
D07
D31
D72
Door handles, Black
D75
DBG
DD8
DLN
DP6
Mirror caps
DP9
Mirror caps, chrome
DRC
Mirror
DRZ
Rear Camera Mirror
DUD
DWI
DZC
E20
E63
Pickup bed
F60
FE9
FHS
G80
GT4
GU6
HS1
Safety Alert Seat
IOR
IOR
IOS
IOT
J61
JBP
JFG
JFH
JFI
JFK
JFL
JFM
JFN
JFO
JFP
JGA
JGB
JGC
JGD
JGE
JGF
JGG
JGH
JGJ
JGK
JGL
JGM
JGN
JHD
JL1
JSE
K05
Engine block heater
K1O
K34
Cruise control
K40
Exhaust brake
K47
K4B
Battery, auxiliary
K4C
Wireless Charging
KA1
KA6
KC4
KC5
KC9
Power outlet
KHF
KI3
KI4
Power outlet
KNP
KPA
KQV
KW5
KW7
L5P
L8T
Engine, 6.6L V8
MCR
MCR
MCZ
USB ports
MGM
MGU
MYD
N06
N33
N37
NB8
NB9
NC7
NE1
NK5
NP5
NQF
NQH
NV8
NZZ
Skid Plates
P0G
P0H
P0I
P0J
P0K
P0L
P0M
P0N
P0O
P1R
P1S
P1T
P1U
PCI
Convenience Package
PCQ
PCY
PDB
SLT Premium Package
PDC
PDG
PDH
PDJ
PDL
PDO
PDQ
Preferred Package
PDR
PDU
SLE Value Package
PDV
PDY
PEC
PQA
PQB
PR6
PR7
PR8
PTO
Power Take-Off
PTT
PXD
PYN
PYQ
PYT
PYU
PZ8
Q7Q
Q7R
QF6
QF9
QG3
QHQ
QK1
Tailgate, standard
QK2
QT2
QT5
QXT
R7O
R8R
R9M
RFX
RFZ
RGE
RGJ
RGL
RIA
RN2
RQA
RSR
Rear Seat Reminder
RTJ
RVQ
RVS
RW9
S0M
S0P
S1O
S3I
S6L
SAF
Tire carrier lock
SBZ
SF6
SFW
SHH
SHL
SKW
SKX
SNO
SNR
SQ9
T3U
Fog lamps
TCE
TCH
TCL
TDE
TDM
Teen Driver
TQ5
IntelliBeam
TRO
TVY
TZS
U01
U1D
Trailering App
U2K
SiriusXM Radio
U95
UD5
UDC
UDD
UE1
UE4
UEU
UF2
UF3
High idle switch
UFG
UFL
UG1
UGA
Recovery hooks
UHS
UHY
UJM
UK3
UKC
UQA
UQF
USS
USB ports, dual
UTJ
UV6
UVB
UVC
Rear Vision Camera
UVN
Bed View Camera
UVO
Bed View Camera
UVS
UY2
V46
V76
VB5
VBJ
VCB
VDB
VDF
VEW
VFW
VHR
VJH
Bumper, rear chrome
VK3
VLQ
VOZ
VQK
VQO
VQZ
VSH
VSX
VT5
VTV
VUD
VUI
VV4
VXH
VXJ
VXW
VYU
X31
YF5
Z6A
Z82
Trailering Package
Z85
Suspension Package
ZHQ
ZL6
ZW9
Pickup bed, delete
ZXT
ZYG
RPO Codes - GMC Sierra/Denali 2500 HD - Is this exclusive to this model only or more?
Edited by Venniebyrd
10 minutes ago, CT Chevy Connoisseur said:
If you email [email protected] they will email you your build sheet which has all the RPO codes relevant to your vehicle.  This is what I did.
I did that last week and got an email saying they no longer provide thaty service
Hello
Thank you for reaching out. As of November 2021, we are no longer able to provide this information. However, you can purchase a copy of the vehicle invoice (documentation of the vehicle cost broken out by model and factory options) by visiting www.gmmediaarchive.com.
With that being said, we're happy to inform you that your Sierra's heated and ventilated seat retrofit is available. Parts needed to complete your Sierra's heated and ventilated seat retrofit retrofit service are available for order by your preferred GMC dealer. We recommend connecting with them as soon as possible to get this retrofit completed. If you'd like our help with scheduling a service appointment on your behalf, or if you have any questions, please don't hesitate to reach out.
Kind regards,
Gerrit M.
GMC Customer Care
They have a separate list for each model and year.
Also, what's included with a code in one year, may not be the same stuff in another.
Z71, for example, has had lots of changes over the years.
On 12/28/2022 at 10:57 PM, CT Chevy Connoisseur said:
Interesting did they direct you somewhere else?
Any dealer can print the build sheet if given the vin.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   2 Members, 0 Anonymous, 1,158 Guests (See full list)
