Pros and Cons of Installing Later Transmission Thermostat with Lower Opening Temperature
3 hours ago, KARNUT said:
Well it’s manual mode with the added feature. If you put it second gear and it hits the rev limit. It’s in manual mode.
Hi Karnut. Could you explain a little more?  I know that if you select an L level that would cause exceedance of a rev limit it won’t downshift, but are you talking about an additional feature or behavior? Thanks
Hello. My last new truck had manual mode. It would shift up to the last gear you selected. Before I got a tune and eliminated cylinder deactivation it was M5. It also had rev matching if I downshifted. It would hold that gear if I desired.
18 hours ago, Another JR said:
Correct. It’s not a manual mode. It is a selectable top gear mode. The transmission will shift normally except it won’t upshift beyond your selection. It can be used in normal or tow/haul mode.
Thats helpful info, too bad the owners manual doesnt explain that. I found that by running under 65mph the truck rarely will try to shift into 6th unless theres a pretty good downgrade. Over 65 it will upshift more often when on flat ground with a favorable wind. I will just leave mine in 5th from now on. I will check on the programming for 6th lockout, maybe they can do that when they do the thermostat TSB.
I tried this out today unloaded, locked it into 5th gear.  Came to a stop, truck downshifted like normal, started off in first gear and upshifted normally until it got to 5th gear, then stayed there.  So the update I have that locks out 6th gear when in TH mode doesn't change a thing when using the L mode.  Good stuff here.
So I just finished up a 750mi road-trip and pulled back a 6x12 uhaul trailer loaded up. Not really heavy but I got to use the truck to tow with. About 3500lbs. I used tow haul. Mine goes into 6th often but not as readily as without a trailer(no tow haul on)
6th with cruise set at 65 is 1,675rpm. When it shifts to 5th it’s at 2,100.
also for the heck of it I noticed my oil life went down 3% towing about 400mi.
Also hit 100 engine hours at 3,668 miles.
3500lbs was not enough to do anything to this trucks temps. 147-151 trans whole trip.
Edited by Pryme
I don't get why your truck is going into 6th gear when in TH mode.  And mine doesn't.  My build date is 07/2022.  What is yours?
Same. In flint. Our trucks might have been next to each other in the line.
I was only towing 3500-3800lbs though. But it was for sure dropping down into 6th plenty. It spent some time in 5th too though. And of course shifts into 4-3-2 and so on when you brake for stop lights etc.
This topic is so weird....how in the hell are our trucks so different?  Programming should have been the same...I'm so confused here...
Maybe ask if you can have them re flash it or whatever with a software update
I don't want my truck updated...I was concerned as to how the other trucks are so different.
You already know you’re going to get a 2024 ha! I can sense it.
  • Haha 1
Hey fellas, they sell bybass kits that just keep the thermo open always. Wouldnt that and a deep aluminum pan be a great way to keep the temps on the low side? Thats what I did on my ram and the temps were alway low. Like 165 was the highest towing 9k.
Knock it off young man....lol....No I'm not!!!  But damn it would be nice....oh stop planting seeds in my brain.  Everyone says I'm easy to read....perhaps I am....NO IM NOT GETTING A 2024.....I'm telling myself that right now...lol..
  • Haha 2
I don’t think eliminating the thermostat is a good idea other than maybe for truck that is always operated in a hot environment. You want the operating temperature to warm up to a stable temperature and design around that.
I still am curious why GM engineers originally decided they wanted that nominal temperature up at 195F. Was it to improve fuel economy by having the ATF slightly less viscous?  Another reason?  They obviously later decided the 153F was a better compromise, but what was the thinking behind the original decision?
Anybody know or care to speculate?
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
