Pros and Cons of Installing Later Transmission Thermostat with Lower Opening Temperature
1 hour ago, Another JR said:
I don’t think eliminating the thermostat is a good idea other than maybe for truck that is always operated in a hot environment. You want the operating temperature to warm up to a stable temperature and design around that.
I still am curious why GM engineers originally decided they wanted that nominal temperature up at 195F. Was it to improve fuel economy by having the ATF slightly less viscous?  Another reason?  They obviously later decided the 153F was a better compromise, but what was the thinking behind the original decision?
Anybody know or care to speculate?
I'm curious why after 65 years of no thermostat they thought it was even a good idea. Yea, automatics ran fine without them for that long. Won't hurt it a bit to have the pill flipped.
Not to be a stick in the mud. You can say that about cylinder deactivation, start stop and a few others. They want just a little more fuel economy. Doesn’t matter the toll on longevity.
Great question.  And I have no idea why they would do that.  Heat is the demise of all automatic transmissions.  They hate heat, it doesn't help them a bit for efficiency with the water thin fluid that we know is called ATF.  So I'm at a loss here.  I can't even think of an extreme example why.  I'm trying....still coming up with nothing....
And where was the automatic transmission fluid cooled at all of those years?  Yes in the radiator with 180 to 195' temps.  So they survived just fine over the years at those temps.  But here's where the problem comes in, and that's with heavy duty towing temps that will challenge the best of coolers.  Things have gotten so complicated it's not even funny.  I can see the reason to slow the fluid down with a thermostat like we have in our engines so that the engine will heat up quickly and the fluid will have time to cool down in the radiator.  Perhaps the same reason applies to the trans. coolers...??  Maybe??
On 3/6/2023 at 8:20 AM, Pryme said:
You already know you’re going to get a 2024 ha! I can sense it.
So yes I went on the GMC site today...I really hate you by the way....anyhow there's a 5k difference between the Pro and the SLE.  The SLE gets the new upgraded infotainment package...the pro doesn't...... you are evil, I just want to make sure you know that... lol...And all these years I was thinking I was Lucifer...Nope...apparently I was wrong...I found the real one...lol...
Edited by Jettech1
  • Haha 1
Excellent point jettech that you don’t need a thermostat to ensure a minimum operating temp when the heat sink temperature (radiator temperature) does that for you.
These trucks have a separate oil cooler, which I suspect drove the decision to include a thermostat to ensure the system warms up to a minimum temperature. I wonder if the original 195F was just trying to replicate a system that uses the engine radiator as the heat sink.
Probably.  A better option than I could come up with.
:crackup:It was a rhetorical question sir :crackup:
Are you getting one haha
On 3/5/2023 at 6:56 PM, Jettech1 said:
This topic is so weird....how in the hell are our trucks so different?  Programming should have been the same...I'm so confused here...
Another data point:  my April 2021 truck shifts into 6th in tow/haul mode. As someone said above, empty truck on level ground accelerating to 60 and sitting there it stays in 5th. Move up to about 65 and it goes into 6th. When I backed down to 60 it stayed in 6th. All of this was on level road.
So how do I get my dealer to put the lower T stat in? I asked about it and he blew me off. I told him the trans temp goes to 215 when towing and 195 when not. He said as long as it stays under 245 I am good.
  • Sad 2
I'm hoping someone chimes in here and tells you how to get the dealer to comply with the update because that's pretty darn hot.  Last September when we picked up our 8k lb camper in Jacksonville, FL and towed it to Byron, GA it was 95' out and my trans temp never above 185'.  So please keep us updated as to the outcome.  Unloaded I typically run in the mid 160's when it's hot as hell out as well.  When I look at your temps versus mine you have about a 20' spread loaded and unloaded.  That's about what I have with the lower temp T stat in mine from the factory.
Edited by Jettech1
I thought someone once posted a tsb or whatever from GM on this. I’ve learned that most ppl will say some silly BS just so they don’t have to do any actual work. That guy is either blowing you off or a fool. Either way, when you get the info and proof, show him so he can be properly trained in.
You tell them you are having a hard 2-1 downshift.   And then you give them the TSB mentioned in this thread which says even without reproducing the problem,  they should replace the transmission thermostat.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
