Just wondering if there ever was any kind of fix for this issue?
I had the trailering app go blank yesterday the first time I ever tried to use it too.
I let my truck sit turned off for about 10 minutes,  when I tried using the app again it worked fine and was very handy.
My truck is a 2020 new to me with 28k and still under warranty for only 8 more months.
I'd love to get this fixed (if there is one?) while it's under warranty.
I have not found a solution yet. I have a 2020 and my trailering app randomly will not start. It may work when we depart camp site and then I will get a blank screen a few minutes later when leaving dump station. Two dealerships have tried different things, but no joy. I'm taking truck in again in a few weeks for service on this problem.
  • 1 month later...
Hallelujah! A software update to fix the Trailering App random blank display has finally been issued (I waited over 2.5 years for this.) Dealership did the update a few days ago (truck still under warranty) when I took truck in for another, persistent service request for this problem. This radio software update, version U168, was released in March 2023. I don’t know if this will be pushed out as an OTA update or if it must be installed by a dealership. Software update details in TSB 23-NA-053 (attached.)
And, update is successful! I have NOT had a Trailering App blank display since update.
Best wishes, I know there are a lot of us that have been waiting for this fix.
23-NA-053 Radio Software Version U168 Update.pdf
Edited by EddDe
Added that update is successful!
  • 9 months later...
I’ve been having the same troubles and bought my 2019+ Silverado with 20k miles last year as a certified used and I am trying to get info if this would be covered by the 12 month warranty?
This is certainly not what we like to hear, SkipHit.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Chevrolet Silverado's trailering app. To do so, please send an email to [email protected] with ATTN: SkipHit/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 3 months later...
2020 Silverado. We are having the same problem as above. The trailering app works occasionally. When it doesn't work it just shows a black screen. When it chooses not to work, there doesn't seem to be anything you can do to get it to work.
Software update available for trailering app blank screen. Also, on my 2020, a body control module had to be replaced for the optional trailer camera to work in the trailering app.
Technical Service Bulletin No.: 23-NA-053
Date: March, 2023
Subject: Radio Software Version U168 Update
  • 1 year later...
Hello everyone, I know this may be a long shot and is very specific to my truck and RV, but I wanted to see if anyone else out there experienced the same thing I am and can provide any suggestions or insight.
I currently have a 2020 Chevy Silverado 1500 LT Trail Boss.  It has a factory tow package with the factory break controller.  Scanning the QR code on the driver’s side, it came with the IOS Infotainment system (no built in nav, just Maps+).  After months of research, I updated to the IOU (advanced trailering app, navigation and wireless CarPlay) version of the Infotainment radio module from Infotainment.com
The IOS version had a trailering “app” on the screen that would only allow a light check and would activate when my trailer was plugged into the 7-way connection with my headlights on.  Additionally, the break controller would also indicate the trailer breaks were active.  Since the install of the IOU unit, when I plug in my trailer, the lights work as intended, as well as the trailer break controller also indicates a trailer is connected, however, the trailering app in the Infotainment screen does not “register” a trailer connected.
When troubleshooting, Infotainment suggested to disconnect the battery for 20 min, then connect, lock the door, turn on the car and reconnect, this did not work.  Additionally, I read that plugging in the 7-way while the car was off fixed this issue for some folks, that also did not work.  I also read information about Chevy changing the “power output” from the 7-way connectors in 2020 and newer models, and that caused a problem with some trailers.  I purchased a Curt 57003 LED-Compatible RV Blade Vehicle-Side Trailer Wiring Adapter, which was recommended to “signal” the Infotainment system a trailer is connected, especially for computers that have LED lights (which mine does).  This is also supposed to solve the problem of the 7-way harness in a custom “control box” as my trailer is a Keystone Cougar 30BHS with a Giggy box, where the 7-way harness is connected to.
I apologize for the lengthy post, but I am baffled as to why this isn’t working.  I pasted some links to different articles and information below.  I also am going to look into the GM trailer simulator (listed below) and also see if any friends have a trailer I can plug into the 7-way or 4-way to “test” and see if its my camper or my truck causing the issue.
Any insight or suggestions are much appreciated, and thank you in advance.
Links:
Curt 57003: https://www.amazon.com/dp/B00AFVOF3M?ref=ppx_yo2ov_dt_b_fed_asin_title
IOU Infotainment Upgrade:
https://infotainment.com/shop/interior-accessories/infotainment-radio-upgrades/2019-2022-chevrolet-silverado-mylink-iou-gps-navigation-radio-upgrade/
GM Trailer Presence Simulator (I am considering purchasing, but it is very expensive):
https://techlink.mynetworkcontent.com/wp-content/uploads/2019/02/GM18-460.pdf
https://static.nhtsa.gov/odi/tsbs/2024/MC-10249034-0001.pdf
https://static.nhtsa.gov/odi/tsbs/2022/MC-10213515-0001.pdf
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
