My refreshed 22 Denali is very accurate. Obviously reads high for a few miles if parked in blazing sun, but it comes down to normal temps quickly.
My 2022 LTD is about 5 degrees off. Been meaning to figure out where the sensor is and see if its artificially inflated due to something with the radiator or whatnot. Historically the sensor was mounted near the front grille in front of the radiator.
It should be under the outside passenger side rear-view mirror
Temperature can vary from location to location.  Whats more reading between equipment can vary.
The temp sensor is located in center of grill below hood latch support.
Well that doesn't track. Because I've replaced my OEM mirrors with Boost Auto towing mirrors and the temp sensor still works...
That's because Boost Auto tow mirrors are shipped with the sensors installed.
Well that’s neat. Thanks for the information
  • 10 months later...
I was told by my GM dealer that this is a know issue. I have a 2024 at4x 2500 with the same issue 8-15 degrees off. Pretty sad that a 90k truck can have these issues. Unbelievable
We regret to hear of this concern revolving around the temperature reading in your vehicle and would like to investigate further on our end.
I haven't even wanted to look at mine lately. Extremely depressing looking at single digit numbers. 🥶
Is it that far out all the time or just at start-up?
On all of my other cars, which are mercedes dating back to the 80s, the thermometer's have been near the road surface. Given that it's asphalt, the road surface is always warmer than the ambient temperature. I assume my truck is the same. It's more useful to know the road temp during freezing or near freezing conditions.
That said, my truck's thermometer seems more stubborn than my others, taking longer to adjust to outside conditions after I pull it out of my garage.
Edited by DubVBenz
The temperature sensor is located on the bottom of the passenger rear view mirror.
  • Thanks 1
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,142 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
