Does it matter that my outside temperature reading is off?  It’s generally ready about 5 to 7 degrees higher than the outside temp.  Of course, having OCD, this drives me crazy, but does it effect anything?  I’m wondering if maybe the air conditioning/heater is impacted by the outside temp when in auto mode, or if anything else is.  Not really worth taking to the dealer, but a bit irritating nonetheless.  Is this common?
My Chevy never reads the same as WeatherBug. Especially when I first start it. It's off several degrees. Usually reading cooler than what the outside temperature actually is.
I have been waiting for a post like this.  It was the first thing i noticed in my 2022 refresh.  it is off consistently 8-30*.  Twice after I got it within a week, i mentioned it to the dealer when i took it back for the stereo issue and they completely ignored me.   Ambiet was mid to high 90s and the truck read 115 one day and 127 the next, both on my 45 minute commute home.    GM has really sh1t the bed with these trucks.
The temperature sensor is in the bottom of the passenger side mirror. If you're parking in the sun it's going to read higher or if it's in the shade it might be closer to actual. Once you start moving then air moves over it and adjust accordingly. All past temperature sensors I've ever seen in factory installed vehicles are in the grill area in front of the radiator. I'm not sure why they moved it to the outside mirror on these trucks.
You would think so, that’s how past cars I’ve owned have worked. My truck though is still off 5-10 degrees after driving for 2 hours over a mountain pass in overcast conditions.
It doesn’t matter if it’s 50 outside or 110, it still reads high no matter how far it’s driven or where it’s parked. Obviously it reads really high if parked in the sun all day, but it cools down to normal 5-10 high after driving it.
I haven’t really noticed it hurting anything besides being really annoying, but I never remote start either.
Same here.  Doesn’t matter how long I’m driving, it never settles in at the actual temp like I’ve had with other vehicles.
This is all going to depend on where you are getting your weather data from.  The truck is probably more accurate than you think unless you've got a weather station at your house or are pulling local weather data from someone who has one running on weatherbug or weatherunderground, etc.
If I look at weather.gov for example, they pull their temperature data from our local airport even if I search for my zipcode.  There is a temperature discrepancy right there from the airport to where I live.
Are you determining the outside temp using a thermometer beside the truck?
Official temperature quoted by local weather station or airport is not likely gonna be the same as the truck's locaiton
I live in S.E. Michigan 13 miles away from the airport. I think it unlikely that there would be a significant difference between the airport reading and my actual reading. However, I happen to have a couple very accurate thermometers and for the sake of discovery, I’ll hook one to my mirror and get a reading.  Can I get a confirmation that the truck’s temperature gauge is in the driver side mirror?  If not, where is it?  I would want to mount my thermometer near the truck’s. Thanks.
The issue I have with this truck is that it bases the HVAC temperature on the outside temperature instead of using a sensor inside the cabin.
It's on the bottom of the PASSENGER side mirror.
  • Thanks 1
Mine 2019 does the same thing.  Never accurate during the daytime with sun.  Poor design, that in testing, I'm surprised this wasn't addressed.
Place a thermometer next to the passenger mirror and compare the readings after a set amount of time. This will give a reading at it's current place regardless what news or weather app says. The truck temp and the thermometer should relatively be the same/close.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
