I have a 2017 GMC Sierra 1500. Ok internet gurus, need your advice here. When I'm using my camper, I would disconnect my tailgate review camera and hook up the camper, on my last trip, I got careless and accidently left some slack in the camper wire harness and it landed on the muffler. Needless to say, I didn't notice any issues pulling out of my driveway but by the time I got to where I was going the wire insulation had melted through and stuck to the muffler. I'm assuming that it grounded out and then shorted something out. I disconnected it at camp and when I reconnected the tailgate camera the blue screen and service rear video displayed. I had hooked up the camper probably a couple dozen times since I owned the truck and also coincidently I broke off the little clip that hold the tailgate wire on this trip so didn't worry that it wasn't working at camp because it wasn't tight. I ordered a new tailgate camera and hooked it up, still didn't work. I ordered a new wiring harness for the camper and tried that, still didn't work. I read through all the threads on here I could find about this problem and it basically came down to three things. 1) Fuses, 2) The Video Control Module and 3) Some type of Program update from the dealer.
I tried checking various fuses but didn't do the Dallas Diag Guy thing of replacing the whole fuse block. Not sure I hit on the right fuse but the taillight, reverse lights and tailgate lock all work. I have had the truck for 95K miles and I take it to the dealer for oil changes so I'm assuming I'm current on software updates but I guess that's a possibility but since this is my first issue with the rearview but I don't think that's it. So, now I'm looking at the Video Control Module as a possibility or should I keep hunting for fuses. Does anyone know if 84624987 is the correct # for my 2017 GMC Sierra 1500 if I go that route? Someone posted that # and someone else posted 84691752, so not sure if that matters. Also, does anyone know what fuse I should be checking?
The scanner shows code B127B
Edited by OkieDavid
41 minutes ago, OkieDavid said:
SOLVED: It's fuse #31, "Accessory/Run/Crank" in the left-hand side fuse panel in the cab.
Ok, quick question... So the fuse #31 had nothing to do with startability of your truck?
Not that I noticed, I drove it for a couple of weeks before I gave up and took it to the dealer, this is the fuse # they identified, and it works now. You would have thought based on the description that I would have noticed something else not working but everything worked as far as I could tell (taillights, backup lights, tailgate lock, etc).
I know this is a bit off topic but when installing a dash cam, I used a piggy back fuse tap on that fuse to wire the power and was highly encouraged to use another because of its description. It seemed to be working just fine but I ended up swapping to another fuse. I also never got around to investigating exactly what was part of that circuit but appreciate the reply. Thanks!
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
