So after a long wait the truck was at the dealer today so I went over to pick it up fresh delivered this morning ,  but I ended up purchasing truck that was on the lot end up costing me 7k more than the truck I order long story short the truck on the lot was 2023 vs mine 2022 with missing options, the truck I ended up purchasing have no missing options and was loaded to the max with hefty sticker price of 77300 any ways here is the picture of the truck I ordered the red one and the black one is the one I end up purchasing.
16 minutes ago, reeseb said:
Congrats! What do you mean by missing options? Chip-dependent options?
yes correct chip shortage , I will post a good pictures as soon as I get chance to take some , also the truck I purchase come with a gun safe and rifle rack under the seat and also gm performance exhaust that sounds absolutely awesome
That's awesome! I think GM uses the Borla Touring as the performance exhaust.  How long did you wait for the truck you ordered?
I order the truck on 4/5/22  and today show up in the dealer I literally watch it unload from the delivery truck.
Man, all those posts and all that headache over waiting on a truck and you bought one sitting on the lot, lol. You could have done that 6 months ago.
Congrats anyway. I’m sure it’s a real nice truck
  • Haha 2
lol I could have not , there was no truck on the lot, I got lucky this truck was order and the buyer backed out of it last Friday  I come today and pick it up, the truck have few options that I don't care about but was nice enough truck so I didn't care, so I got it, I don't care for sunroof gun rack pistol safe performance exhaust  I would never order those options but it is what it is,.... now the truck is in my driveway , I can go and brag about having a pistol safe in my truck than never going to see pistol of rifles under the back seat  lol
And now for the complaint threads about how bad the new truck is.
  • Haha 4
well the ram is way better truck than the GMC by the long shot, is this what you want to hear ? lol by the way I will have the gun safe for sale if anyone is interested , ill post some pictures after I come home from work also the gun rack under the back seat, I don't hunt and I don't need that...
If the dodge is so great, why did you buy the gmc?
There might not have been a truck at your dealer, but there were trucks all over the country sitting on lots and coming in unsold. You could have got one if you worked hard enough to find one and were willing to go get it. I get that maybe that’s not what you wanted to do, but to say trucks weren’t available on the lot is false.
How much for the console safe?
Sure was I was searching for 4 months straight 200 miles radius I was not able to find one every time I think I find one I call and get same answer SOLD UNIT!!
Well, black IS the finest color, so I think you did great.  I hope you’re happy with the new truck.  I don’t think I could have been happy with a partially completed truck.
spends $77k on a truck, can't figure out how to rotate photos on his phone and can barely string together a coherent sentence... LMFAO!
  • Haha 3
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,769 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
