Hi, 2022 LTD LT here.
I have noticed the rear window sometimes explodes when using a remote start with the rear defroster on especially in winter. Is this still going on or 2020~ models do not have this issue no more? Pretty scary...
  • Haha 1
I've not seen anyone complain about this in the newer models on any of the forums I read. Even the daily post of windows leaking has stopped.
No on 2019 to current trucks the rear window has been completely  redesigned..
It basically similar to  Ford and Ram now with the slider in a frame now.
Jokes on you! I just posted about my window leak today! Where’s that damned sad face.
Here ya go. ☹️
  • Thanks 1
OK but like I said there were posts about that daily. Not so much anymore. 😀😂😐🤨😭🤬😡🤠🤮🙊🙉🙈
I hear you on that. I hope that is a good sign that the repairs that have been completed, and that I will now experience, are working well!
