On 4/24/2025 at 5:49 PM, WakeMeUpBeforeYou JOJO said:
I wish I was smart enough to install a drain plug in the pan when I had my tranny rebuilt last summer lol
Dorman makes pans with drain holes for some applications. Rockauto has them at the best price.
GM builds these to fail, you are only putting off what is inevitably going to happen one day. Good luck holding it off.
So my Transmission is starting to slip
I just ordered a circle D 2600–2800 TC and the shift kit. Will I need to tune the transmission or can I just run it with the old program?
thanks in advance
On 5/13/2025 at 10:58 AM, phatrabbitzz said:
You can go with a CTSV converter, 24045127.
Nice find. Price swing from vendor to vendor is huge. Shop around.
On 2/8/2023 at 1:31 PM, 2017 silverado said:
Purchased the new updated thermostat from gm for my 2017 silverado. I also purchased the superior kit #stl010 and swapped the internals. My thermostat hit 144 degrees for the high and 138 for the low temp today. Temp outside is 50 degrees and the hard shifting issue is gone. It kinds sucks had to replace tranny at 62,438 miles.
You did both of them?
  • 3 months later...
Thinking about being proactive and replacing my torque converter before it inevitably fails and does more damage to the transmission. My truck currently has 105,000 miles and I’m not having any issues. I change out 5 qts of fluid once a year. I have the thermostat pill flipped and my Hypertech programmer allowed me to reduce the converter clutch slip to hopefully lengthen its life. I came across this Luk converter that seems to address the flaws with the stock unit. It has a dual disc clutch and the mounting ears are not welded to the case which distorts the clutch surface on the stock converter. They claim 5x the life of a rebuilt converter with a billet housing. Has anyone tried the Luk yet?
IMG_4725.thumb.jpeg.7dad096fab1b6dc3b8751df58fc1e477.jpegIMG_4724.thumb.jpeg.a7c49d69da0f64a7d30f41b82d1225bb.jpeg
Edited by HoosierZ
I may be interested in this as well and will be watching for replies. I have an OEM rebuilt that was installed by a dealer under the extended warranty Mar of 2024. I had 96,000 miles on it then. They come with a 3 year 100,000 mile warranty so I have roughly a year and a half left. So far so good but based on their past, I'm a bit leery of longevity. I figure if I'm still in good shape next year around this time, an aftermarket torque converter is part of the plan. If the trans goes bad before Mar of 2027, I will get a warranty replacement and then have an aftermarket TC done right away.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
