New to the forum, just wanted to share some pics of my 3.0l :
17x8.5 Method 315
37x12.5x17 GT Grabbers
King 2.5 all four corners
Baja Kits UCA
DTM Skidplate
Custom front bumper
Edited by LM2TORO
Amazing looking truck!  I just saw this post after you responded to my other post- What kinda mileage are you seeing with the 37's? And that skid plate is badass- I can't find a metal skid plate for a 3.0L anywhere- Mazzulla has one, but wont fit with the 3.0's intercooler
Edited by paxamus
On 1/20/2023 at 9:41 PM, Chevrolet1 said:
Awesome looking truck!
The front grille & bumper appear to be from a 2019-2021, did you swap?
It’s likely a 2022 limited which is a 2019-2021.
Nice truck
  • LM2TORO changed the title to My 2021 AT4 3.0L
Nice truck
Damn I really fumbled that one. It’s a 2021 AT4 3.0l. Lol thanks fellas.
The skid plate is my own design, I know what you mean man. I was looking all over myself and for $2600+ you better believe im going to have exactly what I want lol.
1 hour ago, Traction said:
Nice! were your previous wheels Welds? what specs were they?
Yes They were. They are for sale as well. 18x9 et-12 On 35x12.5x18 toyos.
$1900 in the Bay Area,Ca if you know anyone interested.
40 minutes ago, Traction said:
I love those wheels. I've been looking at 20x9 0 offset. I wish I was closer, i'd consider an 18" in that case!
Haha nice! Yea I love ‘em, I’ve been debating on just throwing on some 37” and keeping them.
Bump
What's your MPG? TIA
Awesome looking truck.  I love the skid plate and the look of the front end, but can you say you have a bumper?  It looks like you just removed the bumper and put a skid plate in its place.  How difficult was that?  I would love to somehow retrofit one of the new 2023 AT4X AEV bumpers onto my 2021 AT4.
