Does anyone know the offset for the 20" 10 spoke aluminum wheels? I believe they are either a 20x9" or a 20x8.5". Can anyone validate? Anyone know the offset? On chevy's build side and accessory side of the web, they just state 20"
Edited by Mass2500HD
That's a good question.  Here's what I found on google... I hope this helps.  This actually educated me too because I thought it was 20x9.  I was wrong.  It's 20x8
This Factory OEM CHEVROLET rim comes equipped on a 2020 - 2022 CHEVROLET SILVERADO 2500 . This is a ALLOY wheel with a diameter of 20" width of 8 ". This CHEVROLET SILVERADO 2500 wheel has 8 lug holes and a bolt pattern of 8-180. The offset of this CHEVROLET SILVERADO 2500 rim is 47mm.
Edited by Jettech1
I liked those wheels when I first got my truck; thought they were different.  Now that I've had the truck for a year I'm already growing tired of them and want something that actually has a little bit of lip.  Going to stick it out until it's time to replace tires.
I actually love those wheels.  In all my years of owning vehicles, I've only had one that I put different wheels on and that was my beloved 71 Chevy Biscayne that I bought back in 1982.  The poor mans Impala back then lol...I put on some Cragar mags on a 4 door Chevy Biscayne.  But it looked great!!  No really it did...lol....
6 hours ago, Another JR said:
No, I do not like those wheels.
In 2020 the center portion of the wheel was black.  I didn't like that.  It was too contrasting with the aluminum in my opinion.  They went to gray either in 21 or 22.  Now I like them, actually love them.
Factory 17x7.5 Wheel Offset = +44 mm - Back Space = 5.98" Inches
Factory 18x8.0 Wheel Offset = +44 mm - Back Space = 6.20" Inches
Factory 20x8.5 Wheel Offset = +47 mm - Back Space = 6.60" Inches
Lug Pattern= 8 x 180 - Single Rear Wheel Trucks Only
I just wish they weren't so narrow.  If they were an inch or two wider and maybe had a lip on them, they'd be much better.  But as they are, they remind me of pizza cutters.  I'll probably keep them as I don't feel like messing with aftermarket wheels though.
Homewrecker, thanks for providing the specs that OP asked for.  Sorry I distracted from the original post.
4 minutes ago, Maninthesea said:
Wait.  There is a 17” option?   I thought 18’s were min. To fit over brakes.
17" is standard on 2500hd for two trims.  Steel on WT, aluminum on LT.
All 1 ton minimum is 18" because of the higher load rated tires to go with the higher GVWRs.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
