Looking to upgrade my fog lights to either Baja Designs Sport Fog Pocket LED or Diode Dynamics SS3?. Pros? Cons? I have read that there are some space gaps around the pocket. Any thoughts? Worth it?
I purchased the Baja Design Amber SAE fogs for my '20 Silverado Crewcab. I also added a set of S2's (amber) and one S1 (amber) to my back rack (facing the rear). I also added one S1 (white) to the bottom of my rear bumper. I used the Rough Country lighting kit and had it mounted below the center consule (bench). I hope this helps. Cheers...
I'm very Happy with my Diode Dynamics, I have the brighter version and with the driving light lenses they were just too much for public roads, I talked to Diode Dynamics about the issue and I ended up buying fog light lenses (They are changeable, including the amber lenses if you want to change) and once I put the fog light lenses they were perfect, no flashes from other drivers and great lighting.
Best I could get for now, I’ll get better ones if you want over the weekend
18 hours ago, Daniel Formichelli said:
Went with Diode Dynamics should be here Wednesday.
What power level did you go with? The sport version can use a PWM module from Diode Dynamics to be dimmer on low beams, and full power on hi-beams. You'll most likely need the boost auto parts fog light mod.
I went with Diode Dynamics brightest clear lens fog lamps. I use them for low beam driving lights and have never been flashed. The cut off is very good. My truck is a 2021 Silverado.
  • 3 weeks later...
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 474 Guests (See full list)
