What does this entail?  How do you know what it is or if you have it?
Do all 2023's have whatever it is?
2022 had 2 models. The LTD which was the same as the '19-'21 and the '22 refresh. Refresh had a new interior, other standard features and different front end.
Edited by mafd2
What level is LTD?  Is that "Limited"?  I'm not aware of that level but I'm new to GMC Sierra.
I've seen a bunch of different interior pictures and I can't tell what's what (2020-2022).
The exterior is also hard to nail down.  I look up 2022 Sierra and there are like 3 different front ends.  It's all very odd and confusing.
I guess I'm glad I got mine this year, 2023.  I'm new to GMC, was always a Silverado driver, and the levels have changed quite a bit since around 2016 (last time I bought a truck).  Now there are different SLT levels, which is very confusing and not good for business in my opinion.
Maybe it's all to do with the sucky supply issues.
To eliminate confusion, just look up 19-21 (LTD) and then 2023 (refresh). Taking 2022 out of the equation will give you an answer on looks.
I have a ‘22 Limited. It is nothing more than a leftover 21. The 22 refresh has a new interior and a different grill. Otherwise basically the same.
Refresh also has more standard safety features along with projector headlights.
2022 refresh look like 2023.
2022 LTD look like 2021.
Refresh and forward all have new front clips, mid trims and higher have all new dashboards, cluster, radio and controls.  All trims changed vehicle electrical platform to the GM VIP (GM Global B) architecture.
Lots of under the skin changes on refresh.  LTD trucks are on GM Global A electrical architecture, refresh and onward are on GM VIP (Global B).  As a result, the way the modules communicate with each other is changed somewhat, even the tire pressure monitoring and sensors.  Almost all major programming at the dealer is done with the vehicle off now too.
On 2/19/2023 at 3:21 PM, 2016 Sierra Owner said:
Pretty simple. Unless you get the lowest trim level which retains the older dash.
Definitely glad I got the 2023 with the huge screen; my old a$$ eyes need it.  I kind of like the button rail down lower though.
I think I saw somewhere that they just changed the start button, maybe 2024.
Also keep in mind Denali and AT4 get unique dashes. SLT and lower on top, AT4/Denali on bottom.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
