Wonder what to search for or what this handle is actually called or if anyone has the part # for it?  It's the flip up oem handle in the bed.  I'd like to add one to my truck as there is nothing to grab onto when trying to climb into the bed.  Thanks in advance for any replies.
The owners manual refers to it as an “assist handle.”
https://www.gmpartsbin.com/p/HANDLE-inside-Alignment-cam-Release-Tailgate/105863948/85116689.html
This is the bracket that goes in the stake pocket you need to mount the handle. There are also two nuts and a bolt to buy.
https://www.gmpartsdirect.com/oem-parts/gm-handle-bracket-84338560?c=Zz1ib2R5JnM9dGFpbC1nYXRlJmw9MTMmbj1TZWFyY2ggUmVzdWx0cyZhPWdtYyZvPXNpZXJyYS0zNTAwLWhkJnk9MjAyMSZ0PXNsdCZlPTYtNmwtdjgtZ2Fz
awesome, thanks Jon!  Looking at the picture and the parts pictures I see now the bracket would go in the stake pocket and the 2 studs would come through the openings in the bedside and 2 nuts would then thread onto the studs to bolt in place.  Is there a third bolt that goes in the handle assembly to the right?
Yes. The bracket has two welded studs and you need the two matching flange nuts. Then there is a third bolt (not nut) that you need that goes into a threaded hole in the bed. My camper is installed right now so I can’t take a picture of the hole. Here is a picture of my removed handle showing the third hole on the right.
17 minutes ago, Jettech1 said:
Here's what appears to be an aftermarket one.  Now you've got me interested in this....lol....the only thing peculiar is that it states for multi pro tail gates.  No mention of the standard tailgate.
https://ppepower.com/products/tailgate-grab-handle-kit-billet-aluminum?variant=42574311784691
That is just the knob, not the whole handle. If'n you didn't know.
Well that sucks.  I thought I had a shiny new object to install on my truck.... 🤣
The question would be whether all the trucks have the three bolt holes in the bed wall provided for mounting the handle.  Maybe Sonders knows?
Just went out and checked and I do have the 2 vertical holes in stake pocket for bracket to go through.  However the third hole to the right isn’t threaded; just an open hole.  It’s to the right above the top anchor point.
Jon, I'm gonna need you to leave your camper installed and go ahead and send that handle my way.  hahaha.
  • Haha 1
I reinstall it when I have my camper off long enough to bother putting the tailgate back on. They are a bit pricey, aren’t they?
I think if you go underneath and look up forward of the stake pocket you may have hand access to the backside of that third hole. I think on the trucks with the handle a nutplate is installed - probably spot welded in. It’s definitely more substantial than just threaded sheet metal. You may be able to epoxy a nutplate in there yourself if you can get your fingers up there.
yep, checked and I can have my son with his long skinny arm and hand stick his arm up in the bedside from below.  If or when I get around to ordering one, I'll have him reach up there with a nut while I run bolt through on the inside of bed.
Hi, I have a 2020 2500HD WT. Both of those parts show as not fitting my vehicle. Mine looks the same as Brad's, but the 3rd hole is threaded. Any ideas on this?IMG_7708.thumb.JPG.ffa521b73fdb019799e34ce9414f9ed9.JPG
Dave I'd say you're good to go.  Probably says doesn't fit because it wasn't spec'd for your trim level.  I just put a leather wrapped wheel in my truck that said wouldn't fit, but it's in there and working.  Hell you've got the threaded hole so you're a step ahead of me.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
