I posted about this previously and had a decent outcome with reimbursement, wanted to share all the info I can. Looking through the forums, it appears its continuing to happen to more people! I would advise 2019 guys to check your oil cooler lines IMMEDIATELY! Mine is a 2019 GMC Sierra 1500 SLT
I noticed a small leak in driveway after some real cold temps in Michigan. Took skid plates off and noticed the oil cooler lines were leaking on all four connections between the rubber hoses and metal crimps. It appears cold weather exaggerates this issue.
Worst case scenario is those crimps fail, and you lose all of your oil while on the road. Catch it before that happens, and out of warranty or maybe even in warranty, you're stuck with a ~$750 to $1,200 service fee at a STEALERSHIP, just to replace the oil cooler lines (a ~$150 part). It's not an easy DIY job, hence why I paid.
I got quotes at different dealerships for this service. First one was over $1200 at an actual GMC dealership, second one was around $750. I went with the cheaper which was solely a Chevy dealer.
Of course, there is no warranty for this and although their is a TSB for this issue, its only applicable as of now to about 500 trucks. If your truck is in that group, this procedure would be completely FREE. GMC TSB N192220080 - Please reads this through and you will see that GM is acknowledging this is an issue, but for select trucks only.
WE NEED THEM TO ACKNOWLEDGE THAT THIS IS HAPPENING TO WAY MORE TRUCKS.
I called GM customer service to set up a "case" with them, and have been waiting the last few weeks on cash reimbursement. They have already given me $500 worth in GM rewards to use at a dealership, and they are currently in process of reimbursing me cash for the service. I have an email which states they are reimbursing half the amount for parts and labor.  This situation may be unique for others, but get a claim established AFTER paying for the service. You might just get a refund! You cannot setup a claim before the service.
Customer Care:
1 (800) 462-8782
[email protected]
  • Haha 1
How is this not covered under the powertrain warranty, which iirc is 5 year/60,000 miles?  Is the powertrain warranty the reason you're obtaining financial reimbursement?
This has been a problem as long as they have been using oil cooler lines with the crimped hoses. The chances that the hoses can become detached from the metal lines is almost non-existent except maybe in those 500 trucks. My 98 is on its third set so the replacements are not any better than the originals. A more permanent solution may be to cut the crimps off and double clamp the hoses or have a hydraulics shop make some up for you
Edited by richard wysong
Reading around and talking to the service dept, there are def some stories of them becoming completely detached. That is why I am trying to bring awareness to this situation. Based on all 4 connections leaking at the same time on mine, I would assume it would be more likely to detach. Both dealerships recommended I don't drive the truck at all until it was fixed due to possibility of them failing. Yes, you could be right about them not failing, but this isn't something I would risk if they are leaking, get them replaced or as you said, cut the crimp and double clamp the hoses.
I'm at 70k miles but also hoses (oil cooler lines) are not covered under power train. Chances of getting a "Good Will" repair are higher if you are in the power train warranty though. My biggest gripe is that this shouldn't be a wear item at this mileage, it is a commonly known defect on a part that goes bad prematurely. It has happened on trucks that are half the miles. It needs to be revamped, the design is flawed.
Oil Cooler lines are covered under powertrain warranty, specifically so if I remember correctly.
Yep, my 2019 Trail boss leaked during some single digit temps and I really freaked out. Local dealer fixed under warranty no problems other than having to drive a Toyota Corolla for three days.. they even replaced the Oil Cooler for some reason.
  • 7 months later...
Just to remind everyone. Check this. Pull the skid plates and look.
I hadn't been in there for a long time but I just decided to commit to keeping the truck long term, so I tore into a bunch of preventive maintenance and took the covers off, and sure enough, the lines are leaking. And, conveniently for GM, the truck has 67,000 miles on it. I called and referenced that TSB and they basically politely told me to go **** myself. They said it was "possible" that there would be some cost offset for the repair at a dealership, and when I pressed them on how much that might be, she said generally 10-30%, but it would have to be taken in for diagnosis first. I already had the truck on the lift and a bunch of stuff taken apart so I'm just adding that to the list, but it is super annoying knowing that had I just looked 7,001 miles ago, this would be their problem, not mine. This is the kind of ****** I would expect to deal with if 4 years ago I'd bought a used BMW with 150k miles on it, not a brand new $60k truck.
Edited by relevante
  • 4 months later...
Having the same issue on my 2019 Chevy Trail Boss with 80,000. My wife was driving to a doctors appointment , low oil light came on, shortly after that the message about pulling over. She pulled over at the first safe spot. Oil was all over the side of the truck and front of engine. Engine was blown. We had it towed to Shelor Motor Mile in Christiansburg Virginia. It took a week to have it looked at and have to be told that the extended warranty covered the oil cooler hose but have to tear the engine apart to see if the engine blew do to lack of oil for the oil cooler hose blowing. After a few more days Shelor called and said that the engine blowing was due to lack of oil but the only way the warranty place would fix it is if we had the receipts to all of our oil changes. I change my own oil most of the time and have no idea how to retrieve them from my bank statements. We called the warranty place (Costgaurd). They seemed great and said “No problem” they were going to send out their own inspector. A week later we get a call saying that they engine blew do to no oil in the engine and driving with no oil , along with poor maintenance. This is a total joke. Right now still fighting with GM, Shelor and the Costgaurd, trying to find a reasonable person to put 2 and 2 together. Plus Joe ( our representative from Shelor) is a horrible. It sometimes takes days to get back with us. He called my wife today and said it will cost another $1500 to move the truck out of the bay until we if out what we want to do, with addition to the $10028 to replace the engine. This has been going on 34 days. I am trying to reach upper management from Shelor and waiting on GM to get back with us. So far it looks like we have to buy a new engine. Looks like the next truck will not be a Gm or anything from Shelor. They sold us the warranty too. Is it worth going to small claims court? I apologize for the bad grammar. I am a little angry. Any helpful suggestions will be appreciated. I usually would not call out companies or employee’s name but this is completely ridiculous .Having the same issue on my 2019 Chevy Trail Boss with 80,000. My wife was driving to a doctors appointment , low oil light came on, shortly after that the message about pulling over. She pulled over at the first safe spot. Oil was all over the side of the truck and front of engine. Engine was blown. We had it towed to Shelor Motor Mile in Christiansburg Virginia. It took a week to have it looked at and have to be told that the extended warranty covered the oil cooler hose but have to tear the engine apart to see if the engine blew do to lack of oil for the oil cooler hose blowing. After a few more days Shelor called and said that the engine blowing was due to lack of oil but the only way the warranty place would fix it is if we had the receipts to all of our oil changes. I change my own oil most of the time and have no idea how to retrieve them from my bank statements. We called the warranty place (Costgaurd). They seemed great and said “No problem” they were going to send out their own inspector. A week later we get a call saying that they engine blew do to no oil in the engine and driving with no oil , along with poor maintenance. This is a total joke. Right now still fighting with GM, Shelor and the Costgaurd, trying to find a reasonable person to put 2 and 2 together. Plus Joe ( our representative from Shelor) is a horrible. It sometimes takes days to get back with us. He called my wife today and said it will cost another $1500 to move the truck out of the bay until we if out what we want to do, with addition to the $10028 to replace the engine. This has been going on 34 days. I am trying to reach upper management from Shelor and waiting on GM to get back with us. So far it looks like we have to buy a new engine. Looks like the next truck will not be a Gm or anything from Shelor. They sold us the warranty too. Is it worth going to small claims court? I apologize for the bad grammar. I am a little angry. Any helpful suggestions will be appreciated. I usually would not call out companies or employee’s name but this is completely ridiculous .
I got lucky about 2 or 3 years back and they found my lines were leaking during a routine oil change inspection.  The tech said it was actually leaking quite bad but must have just started recently as I was not seeing any oil on the ground or in the garage where I park.  He said the skid plate was almost full with oil.  They were replaced under my warranty
Skid plate is carefully engineered to hold just enough oil to get you out of the warranty period before dripping. Tech screwed it all up by actually removing it for the inspection.
That’s awful. My first line of reasoning with them would be “How did the oil cooler line blow off if there was no oil?” No oil would mean no pressure which would mean no blown oil line. Of course they know this, but they’re just hoping you don’t or that you’ll give up.
I will say, the closest I’ve ever had to an issue like this was with a very expensive plasma TV I bought back in the day. It came with a stuck bright green pixel. The disclaimer in the manual said something to the effect of “defects not visible from more than 8’ away are considered normal.” This bright green dot was visible from anywhere in the room. I went around and around with the dealer and with Pioneer customer service for literally months. Eventually someone on a forum suggested I contact BBB. I figured it was a waste but was pretty much out of ideas, so I did. And within a few days I got a phone call from some VP of customer relations or something like that at Pioneer, and a couple days later two guys came with a brand new TV, set it up and hauled mine out in the same box. So maybe that’s worth a shot? Wouldn’t count on it working but can’t hurt.
Toyota has had this exact same issue for years. It's hit or miss when getting them to cover repairs. I hate that manufacturers use these cheap crimped rubber oil lines.
    phillja
    phillja
  • Who's Online   5 Members, 0 Anonymous, 810 Guests (See full list)
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
    • Lauren Fix Is AI quietly deciding what you pay at the gas pump? How the algorithm picks drivers' pockets.   Every time tensions flare somewhere in the world, gasoline prices seem to jump overnight. Drivers expect it. The news blames geopolitics, oil traders blame uncertainty, and politicians blame each other. But here's the question almost nobody is asking: If computers can raise prices within hours, why do they suddenly become so patient when it's time to lower them? Americans have lived with this frustration for decades. The price of crude oil climbs, and gas stations respond almost immediately. Crude oil falls sharply, and suddenly we're told to be patient. Refiners need time. Distributors need time. Retailers need time. Somehow, that urgency only seems to work in one direction. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. Now a new California lawsuit and a federal push to investigate gasoline pricing suggest there may be another piece of the story that deserves far more attention. It isn't simply about oil markets anymore. It's about artificial intelligence, algorithms, and whether software designed to maximize profits is quietly changing how fuel prices are set across America.   If that sounds like something out of a science fiction movie, think again. Kalibrating the market? Kalibrate is a real pricing platform. The company markets its software as an advanced pricing solution that analyzes competitor prices, wholesale costs, local demand, traffic patterns, and countless other variables before recommending the "optimal" price at the pump. By the company's own marketing, it serves many of America's largest fuel retailers and convenience store chains. Retailers use it because it promises to increase profit margins while staying competitive. There is nothing inherently illegal about any of this. Every major industry now runs on data analytics. The concern begins when pricing software stops simply reacting to the market and starts shaping it. On June 22, three California drivers filed a federal class-action lawsuit in Sacramento — and they didn't just sue the software company. They sued the gas stations. Kalibrate is the lead defendant, but so are Marathon, BP, Circle K, 7-Eleven, Speedway, Walmart, Sam's Club, and Albertsons. According to the complaint, Marathon alone runs more than 1,000 ARCO stations in California and has been letting Kalibrate set prices at them since 2020. Circle K, plaintiffs claim, has more than 400 stations on the software. Albertsons, they allege, has been using it since at least 2009. The complaint alleges that Kalibrate allowed competing retailers to share competitively sensitive information and receive pricing recommendations that discouraged aggressive competition. It describes a "restoration" feature that plaintiffs say lets nearly all the stations in a market raise prices at the same time. It also quotes Kalibrate's marketing, which according to the complaint tells operators that even in the face of "falling oil prices ... it's critical to avoid a race to the bottom," and warns that cutting your price to win customers "could be making a change that triggers a downward spiral." The plaintiffs call the platform the "central nervous system for a conspiracy to extinguish retail price competition among gas stations." Price pumping What does that cost you? Research cited in the complaint found that stations switching to this kind of software raise prices by about 6 cents a gallon on average — and by as much as 30 cents where most of the stations in an area are running it. Plaintiffs point to a real-world example too: They allege that when one California Albertsons turned Kalibrate on, its pump price climbed 3 to 4 cents within days. That sounds small. It isn't. By the complaint's math, a single penny on the statewide average drains $134 million a year from California drivers' wallets. Kalibrate says it disagrees with the allegations, calls its technology lawful, and intends to defend itself. The retail chains have not yet answered the complaint. No court has ruled on any of it. But what happens when thousands of competing businesses begin relying on the same algorithm to determine prices? Price fixing has been illegal in California for more than a century, and the plaintiffs are suing under that old law. What's new is a statute that took effect on January 1 — AB 325, the Preventing Algorithmic Collusion Act — which says plainly that you cannot escape a price-fixing charge by routing the conspiracy through software. Using pricing software is still perfectly legal, but using it to coordinate with your competitors is not. AB 325 makes it unlawful to use or distribute a "common pricing algorithm" — software that uses competitor data to recommend, align, or stabilize prices — as part of an agreement to restrain trade. Whatever you think of Sacramento, it closed that loophole first, and this case is the first real test of it. The A-word Washington is applying pressure of its own — though it is worth being precise about what kind. On July 3, the Department of Justice and the Federal Trade Commission sent every state attorney general a letter urging them to investigate whether antitrust violations or price gouging are keeping gas prices artificially high. "Recent volatility in crude oil prices does not suspend either the antitrust laws or state consumer protection laws," they wrote, "and it does not authorize companies to manipulate retail prices or collude with their competitors." The letter followed President Trump's complaint, posted to Truth Social on June 23, that falling crude prices weren't reaching drivers. But read that letter closely and you'll notice something. It never mentions algorithms. Not once. The federal government is going after gas prices with the same tools it has always used, while the argument about the software is being made by three drivers and their lawyers in a Sacramento courtroom. Nobody in Washington has said the word yet. And whether any of these investigations turns up illegal conduct remains to be seen. Anyone who has driven for more than a few years knows the pattern. Prices spike within days of a geopolitical event, then drift down at a painfully slow pace. Economists even have a name for it: the "rockets and feathers" effect, and they have studied it for decades. Researchers point to several reasons, including inventory replacement costs, consumer behavior, and local competition. None of those explanations necessarily involve illegal activity.   Dirty work   But artificial intelligence introduces an entirely new variable. Unlike traditional pricing models, today's software can monitor competitors continuously, process enormous amounts of market data instantly, and recommend price changes faster than any human pricing manager ever could. If dozens or even hundreds of competing retailers rely on similar recommendations generated from comparable market data, the practical result may be less price competition — without anyone ever picking up the phone to coordinate prices. That possibility isn't unique to gasoline. Regulators have already gone after algorithmic pricing in apartment rentals, and they're looking at hotel rooms, airline tickets, and online retail. The Justice Department sued RealPage over the software landlords used to set rents and settled the case last November. The concern in every case is the same: that algorithms may accomplish indirectly what competitors have long been prohibited from doing directly. It's worth being precise about what that settlement did and didn't say. RealPage paid no penalty, and the government made no finding that it broke the law. What the DOJ objected to was the use of nonpublic information from competing landlords — not the software itself. Using an algorithm to price your product isn't illegal. Feeding it your competitors' private numbers is where the trouble starts. That distinction is going to decide the gas station case too. Technology moves faster than regulation. Thin margins This debate also exposes another misconception. When Americans get angry about gas prices, they aim that anger at the oil companies. In reality, what you pay at the pump includes crude oil costs, refining expenses, transportation, taxes, distribution, and retail pricing. Gas stations generally operate on thin per-gallon margins — the National Association of Convenience Stores puts the net at roughly a dime a gallon once credit card fees and operating costs come out — while state taxes and regulatory costs can dramatically affect what you pay locally, particularly in a state like California. If gasoline prices are rising because of global supply disruptions, consumers may not like it, but they can understand it. Markets move. Wars affect energy. Hurricanes interrupt refining. But if pricing software is reducing competition by encouraging retailers to move together instead of competing aggressively for customers, consumers deserve answers. Artificial intelligence is quietly becoming the invisible middleman in countless financial decisions Americans make every day — insurance rates, airline tickets, hotel rooms, online prices, and now what you pay every time you pull up to the pump. Most consumers never know an algorithm was involved; they simply assume that's what the market decided. Algorithms don't care whether you're commuting to work, driving your kids to school, or trying to keep your small business afloat. They don't understand household budgets or family vacations. They optimize. That's what they were built to do. The question was never whether artificial intelligence can set prices more efficiently. It's whether we've quietly allowed machines to redefine what competition means. Because if software can determine the price of something as essential as gasoline today, what will it be deciding tomorrow?   https://www.theblaze.com/lifestyle/is-ai-quietly-deciding-what-you-pay-at-the-gas-pump
