23 hours ago, Zipp said:
Did you order from Rivard in Tampa as well? My TPW was same as yours and was built. Haven’t heard anything from my dealer since even though I’ve asked if it has shipped. All I get is crickets.
Are you in FL?  I tried calling Rivard to order a few months ago and they said they weren't taking any additional out of state orders.
3 hours ago, 64BAwagon said:
Looks like Precision http://precisionvehicleholding.com/ is having some serious issues in Flint getting the trucks moving. There are a lot of new trucks sitting in storage lots around the area. These are all in areas where the trucks have completed validation and are released to ship.
Rumor has it that there are over 2 weeks worth of production (Flint production is typically over 1000 units per day over 3 shifts) waiting for transport. I think GM needs to re-evaluate their relationship with Precision for logistics. My guess would be that they are a big part of the reason that GM cannot define when trucks will be delivered. Next up is a potential strike, that will for sure send things into a tailspin.
I noticed that Precision is a company owned by an "equity firm" which to me usually means a company more bent on profit than actual quality or sustainability.
Ya I just got a text from the dealer that my truck is at event code 3800(vehicle produced) but it’s delayed due to shipping.
Yea I’m located about 3hrs away in N Fl.
Dealer just updated me that my build has now reached event code 3400(broadcasted for production) but still no tpw at this time
Sammy said call him at rivard, he said whoever said that was mistaken.
Robbie R order from hima couple months back and I picked mine up this weekend.
Getting there... can't wait to see pics
Any idea of how long the build will stay at 3400 before it begins production.
My dealer says I am at 3400 but I just got an email saying my truck is being built as we speak? Who knows.
Patience is key, nothing that any of us do/did made it happen any faster. Theres way too many outside forces at work here. With all of the issues I think GM has to stay pretty flexible and pivot based on supplies.
I was told the same thing.
Call Sammy, he says it's not an issue if he tell yall something different let me know.
8138414748 Sammy
Found out my truck is stuck in a lot waiting to be loaded on a rail cart and has been sitting for almost a month. I reached out the Percision Vehicle Holding on FB and to my surprise, they reached out and are going to try and get it loaded for me.
Edited by Zipp
Nice find!  She is looking mine up too!  Been finished for a month also.
Hopefully they get ours shipped out before the UAW deal deadline! Good luck my friend, let me know what you find out from her!
I am pretty sure Precision is non union. I would guess shipping will still continue even if there is a strike although rumblings are that this one might be ugly.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
