On 10/5/2024 at 8:18 PM, NaturallyAspirated said:
I too think it’s ridiculous that all trim levels aren’t LED. Also don’t like the electric parking brake, but somebody had to make their bonus…
Installed 2 sets of LASFIT LAplus H11’s in my custom. Had to aim them down a bit with a long hex wrench. Performance-wise, they aren’t perfect but maybe 75% of what you get out of an OEM setup IMHO.
I wonder in the long run, if the electric parking brake may save on repair costs? It applies when I'm opening & closing the gate to our woodlot. It probably has been on & off MORE TIMES in 2 months of ownership vs the mechanical e brake in my 2017 3/4 ton that had the mechanical e brake seize up (off fortunately). I know in Ontario, most vehicles have this happen due to the salt & non-use.
Edited by revrnd
Added MORE TIMES
  • 4 weeks later...
On 12/6/2024 at 9:56 AM, revrnd said:
I wonder in the long run, if the electric parking brake may save on repair costs? It applies when I'm opening & closing the gate to our woodlot. It probably has been on & off in 2 months of ownership vs my 2017 3/4 ton that had the mechanical e brake seize up (off fortunately). I know in Ontario, most vehicles have this happen due to the salt & non-use.
I may learn something here... Are you saying that you only let it turn on automatically and that you don’t ever manually?
Sorry to jump in but in my case, yes. The vast majority of the time, I just let it set itself. While Tally does have some contours, and I have used it several times, for the most park it’s running on auto. Every time I go to my son’s house, it sets. At my house, not so much.
Yes...been doing this for the last 20 years!
Normally the only times I use the brake is when jacking it up to swap my winter tires or on a ramp during an oil change.
  • 3 weeks later...
I'm wondering for the 2024 2500 Chevrolet Custom Trim Level with Halogen bulbs is there a brighter Halogen Bulbs that can be installed ? If so would it void the warranty ?
Thanks
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 705 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
