My wife is so sweet, she really is...I love that lady with every cell in my body...but my humor....yeah.....she get's disturbed at times....she's like WTF?  Really...???  I'm like hey, it's humor...we should have sold him when he was 5......then she rolls her eyes and I can see a little laugh trying to come out....it's humor.....perhaps more on the Dave Chappelle humor...lol
  • Haha 1
10 hours ago, Jettech1 said:
I wish I could just walk out my front door to my camper and do that too.  It's being stored at my aunt and uncles house 2.5 hours from us because we don't have the room here.  But I would totally be doing that too if it was 30ft from me.
Its more like 80 ft away, in the barn, collecting dust since its pollen season right now up here.
12 hours ago, 64BAwagon said:
https://www.dexteraxle.com/user_area/content_media/raw/600-8k_complete_service_manual.pdf
Pg 5 "electric brakes" outlines the operation. The wheel MUST be rotating in order for the shoes to be moved into the drum surface. It isnt much but its not like automotive hydraulic brakes that press the pads of shoes into the friction surface by hydraulic pressure rather than a leverage type force.
"Electric Brakes" MUST be rotating is just a little misconceiving for people that know nothing about the mechanics of it. They do not have to be rotating (Rolling), they do have to rotate just a few inches once the magnet is actuated by the peddle or the controller before it engages the shoe to the drum, so if you are sitting still on flat ground in drive let off the brake pedal and engage the brakes with the controller it should not roll far at all before you feel them engage if gain is properly set.
2 minutes ago, 64BAwagon said:
Not sure what your point is. What I said was accurate.
Just clarifying, what I said is more accurate and self explanatory. 🙃
If you haven't ever burnished your brakes, you should do that.  Major difference in trailer brake strength once the shoes are properly burnished.
We will have to agree to disagree. I wasnt trying to flex, just pass on info.
Not flexing either just clarifying, if you read the entire post you might understand. Not sure what you disagree with we are saying the same thing with the exception that it has to rotate some to engage- not be rotating, there is a difference.
Hey gents, I appreciate all the comments here.  You all have educated me and got me back on the right track.  I truly am very appreciative for it all...group hug... 🤗
  • Haha 1
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
