Hello All.
Just bought a 2024 GMC Sierra 2500 HD Denali.  Setting up the trailer, it wanted me to drive forward to calibrate the trailer length indicator and jack knife alert and a third one.  Drove around the block a few times. System says calibrating but no progress bar or any other indicator. Gave up for the day.
I do not have a camera on the trailer, is this the problem?
Did you ever get this figured out? I just hooked my trailer up for the first time and cannot get the jackknife alert or the trailer length indicator to calibrate.
Not yet. Bringing it to dealer end of month. I will post if it gets sorted. A few other users on Facebook also having the same issue. I have also added the camera now still same problem.
I don't think you need to calibrate the trailer length or Jack knife.  After inputting dimensions in trailer profile, if you drive around with trailer.  If you put your turn signal on, you should get the turn signal view with a red area.  This red area is the red carpet view.  If so, the feature is working properly.  I'm not sure on jack knife, I have only demo'd with transparent.  I would put in hitch view and see if an icon is in upper left with jackknife.
If you need help with transparent, let me know.  I have setup about a hundred trailers and know the tricks.  Follow the camera install instructions and drive straight under 30 mph to calibrate.
#iworkforGM
I havent towed with my 2024 yet but I know that my 2021 would take a few miles before it operated properly. Its a less complex system than the 2024 but it still took the truck a little while before it calibrated for the fact that the trailer was behind it.
Thanks. The turn signal view works without the red carpet, it says drive to calibrate. None of the trailering featurs work. I have even deleted the trailer checked measurements and set up again. You tried to help me with the camera install in another post. Emailed GM and It is going into the dealer at end of the month. From other groups apparently the blue hourglass in top left in the below picture is a problem.20230626_144308.thumb.jpg.0f37cb904b1bd5c9978950930061b094.jpg
#iworkforGM
Hi there, I just bought a 2024 Silverado 2500 and don't get the "red carpet" view. Does it only work if it senses a vehicle in that area? Searching around the internet for more info It seems that the trailer length needs to be set for this. I cannot get it set up using my 22' travel trailer. Hoping you might have more answers, info on this topic is slim.
I tried everything I can think of, entered all the data it asked for and I'm in the same boat.  I DO NOT have the trailer camera (yet - supposed to show up tomorrow).
Make sure you height is no more than 118".
The height doesn't affect anything except calibration.
My height is 157" and it works fine on mine. But mine is a 2023, if that matters.
Edited by Dr1ft3r
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
