I got another Software Update installation notification this morning. So I did it. I don't know what it actually good it did,  but now my tire pressures are showing low on all fours. I just checked them with a reliable pressure gauge. All tires reading 35psi. The My GMC app shows pressure @ 31psi on all four, and the DIC has no reading at all. I'll go out in a little while
and see if things straighten out.
Got 2 updates also this week. My tire pressure from Onstar was a bit odd. Said my tires were low and suggested I air them up to over 600psi each, lol. It corrected back to 40psi late in the day
To think as tech moves on, it can only get worse. Vehicles rely on tech to do anything and one simple thing can keep it from driving.
The guy I sold me 2002 Silverado to said he is going to sell it since he really doesn't use it.  Only put 7k miles on it since I sold it to him. He told me I could buy it back for what he paid me for it.  So tempting.
I installed that one on 31 Aug 2023
Didn't have the tire pressure thing with mine.
Truck has had 4 updates.
Two updates on 31 Aug,
One on Aug 25
One on Aug 21
New owner here. Can we actually refuse to accept updates. If we do opt not to would we then face persistent nag screens "reminding us" to do so?
If you decline OTA updates, they will stop sending them and you will have to have them done at the dealer moving forward.  Mine has only done 2 updates since I bought it last year.  A third one was hung in a Paused state after it killed my battery.  Once I charged the battery, it seems to have been removed.  Others had the same issue with that update, so GM likely backed it out.
Thanks. I've check a couple of times since I bought the truck in August and there's been no update available. I don't mind getting updates, but I also don't like to be among the first given that software has a bad track record for being right the first time. And I don't want to be a beta tester for GM.
My last update added a ''red zone'' in the trailer view when the turn signal is on in the dash display with a trailer connected.
I have my trailer measurements added into the 3 trailer configurations in my truck.
My last update showed tire pressure low. Corrected as soon as I drove it. I also received 2 updates within a 3 day period.
The phone app will show update install history and a brief description of what it was for.
    • How many miles were on the truck when you bought it and was there some form of oil change history generated through a dealer or an independent shop although not much would show up if the owner had changed their own oil. Just curious if it was a maintenance issue or if there was something off from the start, surely one would think the original owner would have realized it was using a lot of oil, its hard to go back in time and find out the true story of mysteries like this. Well hopefully the warranty company will go for it and just install a new engine, that would be the ideal outcome.    I still have so few miles on my truck as per not quite 9000 and will be changing the oil shortly which has around 2700 miles on it or so and its down so little on the dipstick from where it was at the beginning of this oil change that I could make the "claim" that it uses no oil but in reality would be a very small amount, less than a 1/16 of an inch. Just driving empty/not towing and easy driving so hard to say what it would do if it had a load behind it for oil consumption. So far very impressed with the very minimal oil usage.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
