On 10/23/2023 at 11:42 PM, diyer2 said:
A lot of people should be glad I'm not the CEO of any car manufacturer because if I was and the low oil light came on I would void your drive train warranty. You've proven you don't care to me.
There is no excuse for not checking the oil.
There's no excuse for an engine to be burning through oil and needing to add oil after 50,000 miles on the engine. When the low oil light came on and told me it was low I took it to the dealership to investigate the problem. The dealership is trying to tell me it's normal (to get me past the warranty). However, they're talking out of both sides of their mouth by telling me it's normal oil consumption rates even though I keep getting a low oil alert 2,000 miles before an oil change. Because if it's normal then, according to them, I should be able to keep driving another 2,000 miles on low oil until I'm due for that oil change. I'm not sure how long the engine can run on low oil, but I guarantee if I did that then they would sing a different tune that there was a problem and I should have brought it in to get looked at and then it would be my fault.
I think we've gotten a little off topic. The original post wasn't about should you check the oil every time you fill up with gas. The original post was why is the truck burning through oil so fast? Why is the truck getting low on oil 2,000 miles before its due for an oil change? Why is this happening on an engine with only 50,000 miles? And is anyone else having this problem?
  • Thanks 2
Your 'best' line is that it is a new symptom of your engine. It didn't use this amount earlier.
It probably still is an 'acceptable' amount of usage to fall within acceptable operating parameters to avoid having to warranty it.
Grumpy explained it all pretty well. Your options aren't great, fight GM, sell it, fix it, add a quart between oil changes.
For what its worth, EVERY vehicle I've ever done an oil change on has had less oil come out in the drain pan than what gets dumped back in. Usually about a quart. Regardless of make, age, mileage, use, etc.
Not calling anyone out, arguing/fighting anyone, but if you tell me yours doesn't use a drop, my first response is BS until I see you measure out the drain pan.
  • 2 months later...
I can't believe they are STILL having issues with this and something needs to be done! They've long since known about the excessive oil consumption, going back at LEAST to the 2014's. There are numerous tech service bulletins about this very thing. If something isn't done, then more and more people will find themselves in our shoes. After purchasing our 2015 Silverado, we brought it in numerous times for the excessive oil consumption.  Initially we were told it was the trans cooler lines or oil cooler lines (can't recall which) and that if it had been the other It would have been covered under warranty but this was a non warranty item. Had it "fixed" .
Continued to have problem. Only after our warranty expired did they finally acknowledge the issue and then stated we needed a new engine. They were right. We did but I didn't go through the dealership to have if done. I saw the parts of the engine and let me tell you it was the worst I've ever seen!!! The crank bearings...were gone..or fused to the crank. Same with rid bearings three bent rods. Everything gummed up to high hell. ****** ton of carbon everywhere. ****** ton of metal everywhere. Timing chain eating away at the oil pump,  causing metal to go into the engine because the timing chain guide was broken, burning and leaking oil and oil not getting to the top 1/2 of the engine for a while now. The block was the only thing semi ok. There was evidence someone had also been in there previously.
I'm starting to think it is a ring coating issue. Moly and chrome have been around forever. But CrN facing and bore spraying are more recent. Seems the ring coatings are delaminating.
Why use them? Friction reduction. When we had moly rings the bore to ring friction was about 40% of the total parasitic drag. These coatings greatly reduce that. Problem is the same as the 1970's EGR pump. We know what to do but we don't know how to do it so let's experiment on the public and get them to pay for the research. IMHO of course.
Anyway, once the coating fails the steel ring (used to be iron) wears the bore rapidly and the result is loss of conformity which give the oil a straight path to the combustion chamber. Blown ring seal.
@customboss would be way more familiar with these coatings than I. I retired 15 years ago. He more recently and has better contacts.
Dizzy has been using oil since 80K on the clock. Now has almost 235K and still using. I keep adding. It keeps going.
Edited by Grumpy Bear
  • Thanks 1
  • 4 months later...
On 10/12/2023 at 12:49 PM, 2020AT4 said:
I have a 2020 GMC Sierra AT4 that I got in 2019. Not long ago my instrument cluster dinged and alerted me that I was low on oil. I thought it was odd because I was still 2,000 miles early for an oil change. I called the dealership and scheduled an appointment, but unfortunately all they did was an oil change, they didn't investigate the problem to see what was causing it. I thought that was kind of weird because just doing an oil change wasn't going to fix it, just like if someone comes in with a flat tire, do they just pump it back up with air and call it good or do they try and find the problem, like, is there a nail stuck in the tire, pull the nail, and patch the hole. I hoped it was a 1-off, but unfortunately last week it did it again - low oil 2,000 miles before it's due for an oil change. This time I checked the dipstick and it was bone dry. There's no puddles under the truck anywhere I park, so it's not a leak in that sense. They filled it up to do an oil consumption test and I have to bring it in every 1,000 miles so they can see if it's burning too much oil. I'm still under warranty. It's a 5 year/60,000 mile warranty and I'm at 4 years and 53,000 miles. Strange thing is they billed me for the oil change even though it's part of their warranty diagnostic test. Has anyone else had this issue where their AT4 is burning through oil too much like this?
I have the same exact issues and they keep recommending me to pay to diagnose it.  The dang thing is under warranty.  Two quarts low at 4k, and have to add two quarts every time.  They all consumption test only does every every thousand miles for three inspections. My oil doesn’t start burning until it gets after the 3000 as soon as it hits 4000 miles I’m almost exactly 2 quarts low.  They tell me that’s normal which with all the cars I have I’ve never had that problem before with any of them. And I get a misfire two or three times on multiple cylinders every day it’s been in and out of the shop at least eight times and three times for an oil consumption test. I think they know there’s a problem they’re just trying to get out of it because they’re a lot of vehicles out there that have the same issue after reading a bunch of message boards started about click 60. They say it’s out of warranty now but I have the extended warranty. I think GM just trying to kick the can down the road so they don’t have to fix all the vehicles because it will be a massive recall. It’s back in the shop now for the same reason. I’ve always been to GM guy, but after this, I think I’m done.
  • 4 weeks later...
Same thing here truck is shiny and gorgeous and uses more oil than my 1933 Hot Rod or my old Ford tractor.
GM is humping me like the guy on Deliverance.
Filthy B*stards, I will NEVER buy another GM after this even though they are offering 1.9% on he HD's..lol 😂
They are so stupid that when my oil does not register on the stick, they call it half a qt low and I say hey MOFOS I have a qt right here lets pour it in, they say well lets pull it into the shop and uhhh you are not allowed in there for safety reasons  Hhahaaa on me. it makes me want to go on a window spree at night with  a hammer .....just sayin.
FOCK GM they KNOW this is a problem and are burning us as they get another HUGE bailout from the taxpayers for their Biden EV screw ups.
One of the dumbest posts ever given the context of the post from the OP, 67K for a truck with 40K on it and you drive to AZ and back and the MOFO has used 2 qts of oil.  Now THAT is stupid and the manufacturer should be sued. 8 qt system for a reason..lol
On 10/24/2023 at 9:54 AM, Grumpy Bear said:
IMHO the frequency that one checks oil is a trust built between the owner and the vehicle. I trust some more than others. But it's based on my experience with the vehicle.
Circle back, take a breath. It is wrong to use that much oil. It is wrong to not check it. But we all get taken by surprise now and again. You let that light come on more than once and you are no longer ignorant of your situation. Is that a compromise?
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 522 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
