This is definitely a dumb question but I was at a pick a part and there is a turbo charger in an old ford diesel engine. Could I take the turbo from the diesel possibly a 7.3L and put it on my 4.8 v8?
A person with the proper skills could do anything. The easiest way to go is to buy a kit. That is if you’re vehicle can handle the upgrade.
Right, you could do anything with the right fab skills.
Make your own hotside exhaust pipes, intercooler pipes, oil feed and return lines, bigger fuel injectors and fuel pump, 2 bar map sensor and things like that. Then tune it so it doesn't blow up.
  • 3 weeks later...
Swapping a turbocharger from a 7.3L diesel to a petrol V8 can totally be done, but it's a bit of a nuanced process.
First off, you gotta think about whether the turbo jives with your V8's vibes – check things like exhaust flow rates and pressure ratios. And get ready for some custom work because you might need to fabricate mounts and sort out intercooler plumbing. Diesel and petrol engines have their own needs, you know?
To really amp up the performance, you'll need a custom tuning solution. Time to tweak the fueling, ignition timing, and boost control to make everything play nice with the new setup.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
