Hello All,
Been browsing the forums for a while and wanted to ask a few questions specific to my needs. I am really torn between which wheel size to go for. I drive a 2017 Sierra Denali that came with 20" wheels. The truck despite having MagnaRide suspension rides a bit harsh in my opinion.
I was doing some research and found out that smaller wheel size should make the ride a bit comfier but I am torn between the wheel sizes and suspension itself. I have a suspenion leak on the front passenger side and I am wondering if I should just replace them with the same MagnaRide or go for something else? I read about Bilstien 5100 would you recommend that over MagnaRide? Are they comfier compared to MagnaRide?
Now, regarding the wheel size, should I change the wheel to a smaller diameter or go for a softer rubber (If anything like that exists?) on 20" wheels?
Between 17" and 18" is there a massive difference in ride handling and quality? I ask because the GMC 20" wheels that I got come in 18" as well with the same design but doesn't exist in 17" which means probably an aftermarket wheel needs to be purchased but I like the design of the 20" wheel more and thus would like to keep that if possible.
The mileage on the truck is 130,000 Kilometers/80,778 Miles in case that matters.
Thank you all!
I'd handle the shocks before you change wheels/tires out.  A bad mangeride shock can ruin the ride no matter what wheels/tires you've got on there.
What you choose is up to you.  You can get new magride shocks.  You can bypass the magneride and throw some regular shocks on there.  Bypass kit is needed to fool the suspension control module so you don't end up with lights on the dash.  As for what brand, I can't speak for any really.  I've seen hit and miss on the Bilstiens though on here.  Some love them, some had nothing but problems.
To me, handling wise the 20"s offer the most handling in terms of cornering grip, especially when paired with a sport truck tire for summer only use.
I've had 18"s on 3 of my trucks now and they've been a nice balance on the ride and handling.  More compliance than the 20"s but more control than the 17"s.
"Soft" tires?  In my mind that would be more compliant sidewalls, which would be Michelin.  You should see how easily you can manipulate the sidewalls when they aren't installed on a car/truck lol.
Thanks for the response. I have an opportunity to change MagRide to Rancho (White shocks) that come on Z71 4x4 package. Do those ride good? My eventual goal is to install King 2.5 but that's most likely towards the end of the year.
So, I see then 18" wheels should be good.
Any particular Michelin model that I should look into?
Thanks!
Thanks!
The stock Ranchos from a Z71 are another much debated shock.  My 2018 had them, I never had a problem but some people hate them.
Michelin's bread and butter tire is the DEFENDER LTX M/S.
Thanks!
Hello!
Just wanted to offer my personal experience here. My truck came from the factory with the Ranchos. If you are looking for a comfier ride, in my opinion, I don't think the OEM Ranchos will be a big help. They're not a bad pair of shocks, but they provide a super stiff ride and I think the transition from MagnaRide to those shocks will be very jarring.
If it's of any help, I actually swapped the OEM Ranchos years ago with Bilsteins and I have been really happy with the ride quality of my truck.
I believe the regular Defender LTX in many sizes is discontinued but you get the improved designed Defender LTX M/S 2's now. Not that is matters too much, it's still their best selling tire.
I should know, I see them everyday because of my job lol.
Not going to respond to the shock question, but to the tire question.  If you want just a road machine that handles almost like a car I recommend the Bridgestone Dueler H/P Sport.  I had them on my previous truck and liked them so much, when I got my '23 Silverado I sold the OEM Generals and bought the Dueler's again in 285/60/18 size.  But, checking Tire Rack, I see they are no longer available for 18" wheels, but only for 19" and above.  It is a summer tire.  I luv 'em👍
Lou
3 hours ago, OffTheAir said:
Hello!
Hello! Which Bilsteins did you go with?
Thank you! I guess I'll skip Ranchos then.
I shall look into the tires.
Lou
Thanks, lowrider. I'll check out these rubber too!
I went with the Bilstein 5100s, very happy with them.
I don't mean to answer for @OffTheAir, hopefully he'll give a response soon with his experience on which Bilstein version he installed..
Edited by MikeBMW
Hey Mike, you switched from Ranchos or MagnaRide?
No, I went from stock to the Bilstein 5100s on a 3" lift  all around and a 1.5" rear spring lift, 1.5" body lift and a 1" lift with the front Bistein 5100s.
Nice! I know stock are very bad suspension.
What's your wheel and tire setup?
You have a Denali. Stick with the MagnaRide. They are the best shock out there for the K2 trucks.  I had three K2 GMC SLT's and the stock Ranchos SUCK compared to this 2018 Denali with MagnaRide. No comparison
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
