I have a 2020 GMC Sierra 3500HD that came stock with 18" wheels and 275/70/18 tires. I want to go to the Denali wheel/tire that is 275/65/20. Question is can the dealer reflash the ecm to reflect that change? the 275/65/20 is 1" larger in diameter. I would think that it's possible because the powertrain is the same.
The dealer can't/won't do it unless you bought accessory GM wheels and tires from them.  That's the only way they can get a calibration for different sizes as they can ONLY do it for GM approved tire/wheel combination.  Doing it for customer supplied wheels/tires  has liability concerns.
Edited by elcamino
It all comes down to if that wheel/tire combo could have been ordered for your truck as a standard wheel/tire option.
So if you have an SLE that was ordered with 18"s, but when ordering it could have been ordered with 20"s, then yes GM would be able to issue a new calibration.
If you have a base truck (Sierra Pro), those could only be had from the factory with 17" or 18" wheels/tires from the factory, so GM would NOT offer it.
Here's the PI explaining recalibrations - MC-10227674-9999.pdf (nhtsa.gov)
The only other approved way to calibrate is a GM accessory wheel/tire package.
Rough country make's a speedometer recalibration tool
I have one that I have used on my 2020 &2022 2500HD
when going from 20" summer tires to 18"winter tires
Edited by elkhunt
  • 4 weeks later...
I would save your money, your originals are 33.2 diameter and the new ones are 34.1 diameter which means at 70mph your only out 1.9mph. You won't get pulled over for that difference in speed. It's out even less at slower speeds, not worth it in my books. Tire Size Comparison
  • 4 weeks later...
The Banks iDash has the ability to calibrate the speedometer (as a percentage difference from stock tires). This is just one of many benefits to owning the gauge. (EDIT: Correction, only the iDash will show corrected speeds)
Edited by davidm767
The Scangage2 and Scangage3 also have the ability to make adjustments to the speedo.
I had the SG2 on my 2005 Duramax with 285's instead of the puny 245's   I could adjust the speedo but I dont think the odometer was ever completely accurate.
Before you go down the road of researching speedo calibration, put the tires on and see how far off you actually are. I put 295/65/20s on my '22 which are 1" taller than the OEM stock tires and my speedo is a dead nuts match to my GPS and roadside radar. IMO, its not a big enough difference or deal to calibrate a speedo. If anything the speedo will show slower than actual speed.
I am using a Pulsar LT with great results. After a little experimenting with stock size vs current I've got the speedo dialed into GPS speed on the nose with 37s. Added benefit of running 50psi all around with no TPMS warnings as I've dropped the threshold to 45. The reduced throttle delay also gives a great response and helps mitigate the 2-1 downshift clunk as well.
Very happy with the unit
  • 2 months later...
Is there any calibration tool for the 2024 models? Rough Country and Pulsar LT don't do it.
Same problem here. I believe until enough companies learn to crack into the new ECU architecture it may be awhile. Until then I've memorized my speed correction between 50-80mph and Banks iDash provides a corrected speed. However they have not provided a way to reprogram the ECU to adjust for size.
Edited by davidm767
  • 1 month later...
I have the opposite problem on my 2024 2500 AT4. I like 18 inch rims instead of 20’s so that the truck rides better with more sidewall. They told me they could not order the 18’s at the time and I had to get the 20’s option. I made a deal that when the truck came I would get 18 inch wheels and tires swapped. In the past the outside of the tire never changed with factory wheels only the rim size  and sidewall did.
So I got the truck and new rims and factory sized 18 inch tires. I have come to realize the 20 inch rims had 34 inch tires and the 18 inch factory tire size are only 33 inch. My speedometer is out 5%. So I have to do 105kph to actually be going 100kph. Not the worst thing but here is the catch - I am going to lose my warranty early. About 5000 km early. And that sucks.
Two dealerships said even though it is factory size they can not adjust the speedometer. So I am searching for solutions. Yes I could just buy tires that are 34 inch OD but tires are expensive and with. 1mm offset the 33’s just barely do not rub anything. I hate rubbing. 34s will rub.
  • 1 year later...
That tire change will most likely make the current calibration of your speedometer and odometer accurate.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
