I have a  '23 1500 w/Bilstein 6112 + 5160. They are quieter over bumps which is nice, but they are racecar stiff & I can't stand them after ~4000mi (yes they'll be for sale soon).
Most of my driving is on the road (bad ones) and they are much stiffer than the OE z71 ranchos I pulled off so every little bump (again there are billions) goes straight through my spine.
Can anyone recommend something with less damping that will let the springs travel a little more? I am currently considering these Monroes:
Tires are also a part of the 'suspension'.
Did you stick with the standard 18" rims and factory tires?
Have you adjusted air pressure to match the actual axle weights for your application?
(I'm assuming you aren't running at max rated loads)
It's less of a dampening issue and more spring rates. It's a truck. You need a coil over with selectable spring rates and tunable dampening. King, Fox or similar. I run Kings with 600# springs and could go lighter but much softer than the 750+ progressives it comes with. Of course you have to concede some load capability. Back half is harder still. Few selections to choose from. I had Deaver make mine with 15% less rate. I'm not full car mode but halfway there. Big improvement and I don't care as I'll never ask my HALF TON to carry a ton and a quarter.
What tires do you have and what PSI are you running.
You could go down to a Bilstein 4600 that’s more of an OEM replacement shock.
I am running the stock 20s at mid 30s PSI when warm.
I am thinking about selling these and going down to a 17" with more sidewall, like Michelin LTX AT2 or just M/S
good feedback - what did the custom Kings & deaver leafs run you?
Yes Bilsteins (5100s and up) are really stiff.  I hated them too.  On my Tahoe I immediately switched to Rancho RS9000xl...they are adjustable and I was able to play around with damping until I found a place where the truck was very composed but the ride was not ridiculous like the Bilsteins.  That said, the quality on the RS9000's is not fantastic...though Rancho is a great company to deal with when you have issues.  I've heard the new RS7MT's are a great product but I have not tried them myself.
The Fox 2.0's are fantastic both in performance and quality but that's a major price jump from either Rancho or Bilstein.
The entire suspension remake was about $4,500 and for me, worth every penny. A mild 2/4 lower was part of the job that included Bell drop knuckles and Sulastic shackles.
If the lower wasn't part of the equation, then Fox and a set of springs from an earlier half ton would cut cost considerably. Or even removing the middle leaf and a tunable/rebuildable shock (Accutune) with a linear piston and selectable front coils. They work together.
AccuTune Off-Road (accutuneoffroad.com) or Filthy Motorsports | King Shocks and Off-Road Racing Parts
The hardest part of working with these off-road guys it is getting them out of their off-road mentality and into street mode.
:crackup:
I used FMS and the King factory 12 studder 12 valving was good out of the box after a few thousand miles break-in.
If you do this REMEMBER you lose payload. You're tuning to run closer to empty. This, I hope, makes the obverse true as well. Adding weight over the rear axle has the same effect as softer springs. Even makes the shocks ACT softer. (Less progressive)
I actually did both. A spray in Premium Line-X, tonneau cover and the thick rubber matt with it added about 400#, I had to add some nitrogen to the back half.
DSCF3007.thumb.JPG.37919c94e2c090f4693d34128dc9b8f9.JPGDSCF3008.thumb.JPG.ef72d8dc3caadd309f0a597ade29d3e8.JPG
Edited by Grumpy Bear
The 6112's are essentially a 2.5" shock with a heavier spring. You could step down to 2" shock and a stock spring like the 5100 or the fox 2.0 IFP's use. Which would be much cheaper. Fox makes a in between 2.0 with a new coil that may be a good option for you to pair with the 2.0 IFP's in the rear.
Or like above, the bigger shocks. King/ Icon run 600 to 650lb springs on their coil overs. Fox runs a 550lb spring. But then with the bigger 2.5's you can opt for compression adjusters to fine tune it. Its really about budget.  If your up for $3-5K, then look at the Fox/King/Icon route. if your more $1-3K, then look at the Fox 2.0 series or the 5100's with a stock spring. They will be firmer, but nowhere near the 6112 firm.
With any of them, the more your preload the coil for lift, the more firm it will feel. thats the trade off for a lighter spring rate vs. heavier spring rate as well. Most A-Arm is a 2:1 motion ratio so once you have the coil loaded at the point of maintaining ride height/stock weight, then every .5" of preload will be about 1" of lift.
If your 2WD like me, a lift spindle is the best choice since it's doing all the lifting and you can set the shock up to be super plush. CST makes a 3" fab'd spindle, and then Maxtrac makes a 3.5" cast version. CST being MUCH stronger and allows for a 17" wheel.  This is what I did. Only thing is your limited to a ball joint upper arm vs. a uniball due to the taper. Lots of options there though.
Edited by Vincej138
You think these 2.0s (highlighted) would fit the bill then? Do you think they'd still yield a much firmer ride than those Monroes?
:crackup:
This is very detailed, wow - is there math already available to understand how removal of 1 OE leaf would affect my payload & towing?
I am looking for simplest past to get 80% of what I'm aiming for, hence my hard 180 to an OEM-like solution like those Monroes.
It's sounding like the Fox 2.0, removing 1 leaf, and using accutunes get's me damn near what I'm looking for.
Yup, those are the ones that come with a new coil. The one above needs a stock coil
https://www.shocksurplus.com/products/fox-2-0-performance-series-coilovers-shocks-set-for-2019-2024-chevrolet-silverado-1500-4wd-rwd
Here are the stock coil version, which may suit you better honestly. Rears between the 2 are the same
https://www.shocksurplus.com/products/fox-2-0-performance-series-coilovers-985-62-012
The Monroe's are gonna be soft, they just dont have the nitro, valving, piston size. its a oil carrier.
Watch this video and some of their other Silverado guides. One of the employee's tested all diff variations so you get a lot of feedback.
Edited by Vincej138
Thank you that 2nd link with the stock springs - what is the rate on them? 550#? 600#?
Regarding Monroe, if soft is what I'm after (I am, to be clear) - are they worth a shot?
Thx also for the video, going to check it out now
Edited by 23RST
7 minutes ago, 23RST said:
Thank you that 2nd link with the stock springs!
They could be. it would be comparable to how it was stock. A lot of "soft" is subjective person to person. To me soft is rough as your bouncy and any somewhat harder hit you may bottom out. Prior to my Fox 2.5's i had 5100's and like in the video, the firmness was nice cornering and towing. Fox's are kind of best of both worlds IMO.
If your looking to just get back to stock like ride then ya, monroe's will be okay for you. If your wanting any lift and any sort of off-road or track/sporty performance then they will be lacking. I would almost go to a dealer, drive a bone stock RST and then base it off that feel. if thats what your looking for, then monroe. If its too soft, then likely go fox 2.0's since the Bilsteins are too firm for your taste.
Edited by Vincej138
I run 18" in winter instead of the 20's the truck came with.
I've done this on several 1500's.
I find they ride better, but don't 'handle' quite as well ( more 'roll' when sidewalls flex in a tight turn)
GM still has these on 2024's   I got may take-offs in late 2020.
(I thought they were off a 2020/2021 AT4.
Today they show as standard on SLT and available on Pro and SLE
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
