2023 Silverado High Country rear panel behind seats........
Name that component, I know some of them but not all (some are very obvious) so someone else will need to verify who is correct!  😁
3
4
5
6
7
3 Cab Vent
4
5
6 Seatbelt Retractor
7
1: rear window motor (for sliding rear glass)
2: video processing module https://parts.chevrolet.com/product/gm-genuine-parts-video-processing-module-(programming-required-by-automotive-professional)-85004218?body=Crew Cab Pickup&bodyId=22&bodyNumDoors=5&bodyNumDoorsId=5&categoryId=3074457345616983734&make=Chevrolet&makeId=47&model=Silverado 1500&modelId=491&year=2023&bac=115369%2C115352%2C320852%2C178250%2C290298%2C115372%2C290911%2C202475%2C289459%2C172522%2C131030%2C285418%2C306530%2C115381%2C115353%2C311963%2C115368%2C115378%2C286519%2C307117%2C115385%2C115359%2C316437%2C286058%2C113532
3: Cab vents (for when you slam your door shut they flip open and release the excess pressure in the cabin)
4: Audio amplifier, part #: 84813325
5: looks to be the 110v power inverter, part #: 84962936
6: seatbelt retractor
7: i'm not 100% but it looks like the rear parking assist control module, part #: 85131831
Edited by kickass audio
Awesome job!
I wasn't sure of #2 and #7........the rest I was pretty sure of and you confirmed.
Mounting of #7 looks like a little kid did it. 😁
Edited by BigMick2023
3 hours ago, dieselfan1 said:
Why is the seat removed ?
Working on adding an JBL amplifier and powered sub woofer.
Ordered harnesses to plug into the Bose amp from AIS.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
