New Samsung S24U won't charge wirelessly. I put it in the slot, it shows charging for a few seconds then goes to the yellow warning triangle. Tried without the Otter Box cover, no help. My S21U didn't have that problem. Anyone else with the S24U have this problem?
Does it charge wireless in another vehicle or at home? How discharged was the battery when you tried? Most new phones use optimized charging so they may not charge past 80% to increase battery life. While I don't have a Samsung phone, our 23 Tahoe will charge both my iPhone and the wife's iPhone just fine as long as they are discharged below 75%.
As far as I am concerned, wireless charging in these refresh trucks is useless.
Unless you have the ONE phone GM used to design the system, which is probably the first phone that ever had wireless charging and has not been made for ten years your phone will not sit in the massively oversized slot correctly.
You will need to find out how high off the bottom of the slot and how close to centered you have to be to get a solid charge, and then make an adapter to fill up the excess space to have any chance of it ever working.
My current best setup is 1/2 inch from the bottom and evenly centered, charging port down, screen up, on my Samsung Z Fold 4, but it's not foolproof.
I may buy some of these and use one for a month to make sure it's a solid place, then have someone 3d print me a filler.
https://www.amazon.com/Dashboard-Removable-Silicone-Anti-Slip-Non-Slip/dp/B09NNRWNVK
in my 2024 1500 using my s24 phone , I have to slide it into the charging pad on my console with the top of the phone facing the rear of the truck, face up. this works on 2 out of 3 s24 phones. The 3rd one the case is too thick to waork on any wireless charger.
Hope this helps
My Sierra is the only vehicle we have with wireless charging. At home we use a standard charger. My previous S21 worked fine. My wife's S21 does as well. First try with the S24U it was at 62% charge. Thanks for the info.
Depends on the phone, the placement of the phone and the phone case. If I keep my case on, it won't charge. If I remove it, it will charge.
I had this fixed in my truck. Go to the dealer with the no wireless charge complaint. There is a service bulletin about it. There are several different modules that can only be identified by disassembling the entire center console and getting to the bottom of the wireless module. If it's the first type, they replace it. If it's the second type, it is the correct hardware and it needs a software update to charge Samsung phones. If it's the third one, there is another problem. Mine got the software update and has been working since without issue on a s23ultra. If you look at my previous posts
, you should see the bulletin number to give to the dealer if they can't find it for some reason.
BOBDER41 YOU ARE THE MAN! I just bought a s24 ultra and I work at the damn GM dealership as a salesman, I never thought about trying that but it worked perfectly. Thank you very much !
My S23U would usually charge , but my new S24U does the same behavior that you describe. I need to check it without my case on, but on the S23 you could move the phone around a little and find the sweet spot/orientation for charging. I haven't found the same with the S24 Ultra.
I must have super - charger in my Denali Ultimate. I have a Samsung S22 Ultra and S24 Ultra and both immediately start charging with silicone cases. Top toward front.
Edited by Jus Cruisin
My 23 Denali has been hit and miss with my Pixel 7 pro. I got used to cursing at it and adjust it couple times then it seems to locks in.
This post is exactly what I need! Thanks! I am going to try this with my dealership. I have a 2022.5 Sierra Denali and have this charging problem on my Samsung S25 Ultra and iPhone 15 Pro Max. I am out of bumber to bumber warranty but have an extended warranty. I will report back with my findings...
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
