This is the crap version of the eliminator that causes battery drain and possible dead battery. GM even put out a service bulletin about this and the solution is to remove the unit and charge the customer for the service.
I just drive in manual mode and put it in L9.  No more auto/stop or DFM.  MPG didn't change either.
  • Thanks 1
I thought it was the other way around and the in-dash version was the unit causing battery drain?
Edited by Aubie_01
14 hours ago, newdude said:
But the button already installed on my dash is free.  So is driving in L7 or L8 on an 8 speed or L9 or L10 on a 10 speed truck.  $ Free.99.
newdude L10 also disables DFM? So I can use L10 instead of L9 to disable DFM?
No.  L10 is the same as D, just disables any sort of grade braking.  DFM will be active in L10.
Edited by newdude
  • Thanks 2
7 minutes ago, customboss said:
If you have the 2.7L of any year running in manual forces 4 cylinders operating all the time? Correct @newdude
Yes driving in L7 defeats AFM in the 2.7 as well.
  • Thanks 1
Well I thought it may be of interest to some, obviously there is a market for it and I certainly would not want you to miss the joy of Focking with that button everytime you drive or driving around playing with the shift lever😁
Cheers
Been pushing the button on my dash since May of 2021 when I got my truck. Still have the $100 in my pocket and no dead batteries!
Glad to hear it, I myself bought the Pulsar and have not worried about buttons nor do I have a dead battery.
Nor do I have to fondle my shifter to disable any phony EPA/Govt. garbage.
To each there own.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
