Shortly after returning from a 450 mile (round trip) hunting excursion I took with the truck last week, I noted that the truck was apparently leaving half dollar sized oil spots on my clean driveway wherever it was parked.  Have owned this 2025 2500 for less than one month and at 1,180 miles I crawled underneath to see if I could isolate the leak that was staining my otherwise pristine driveway.  Indeed, I noted transmission fluid seepage on the driver side rear corner of the transmission pan.  I drove it to the GM dealer and the service rep crawled under the truck and also noted fluid around the pan; worse yet, he said he thought he could feel fluid on the top front side of the pan which suggests bigger problems with an eye toward the transmission (seals, whatnot). The truck has been with the dealer for several days and I'm still waiting to receive diagnostics report and a repair recommendation.  I have read other relatively current posts here from other model year 2024 GM 2500 owners with fluid leaking from the 10-speed Allison Transmission at very low mileage and this has me a tad worried and annoyed.
Needless to say, this is a huge disappointment in GM quality assurance, not to mention a colossal inconvenience because I cannot otherwise use my new truck.  After all, who expects their brand new $90K+ truck to have major mechanical issues?   I'll provide an update whenever I hear back from the dealer.
We are sorry to hear of this leaking concern you are facing with your vehicle and would like to take the time to learn more and assist. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
Just heard back from the dealer service rep on the tranny leak.  Evidently, the GALLEY PLUGS are leaking at the rear of the Allison Transmission.  They are awaiting parts and will remove and reinstall the OEM factory plugs to hopefully solve the problem in a couple of days.  Was told it is a fairly non-invasive repair and as long as it is indeed the cause of the problem AND it can be successfully mitgated, I'll be glad to have this rig back on the road again.  I realize S(tuff) happens, but I'm increasingly disappointed in GM quality assurance as a result of this.  I've owned nearly a dozen GM trucks in the prior 30 year period and never had (or heard of) issues like this occurring (from 5 seconds after I owned the truck).  Get your S(tuff) together GM team!!
Sadly its all brands right now, not just GM.
Starting to sound like Toledo propulsion is having issues. The latest bulletin about the filter change for debris has me a little nervous. I checked with my contact at the dealer and he said they didnt have any further info on it and that unless my VIN showed an open status on that bulletin they couldnt do mine. I havent been able to find any info on number of affected units other than the bulleting saying it was a phased rollout. I heard an unsubstantiated rumor that it was related to the machining finish on one of the drums shedding material but I dont have any info on that. Just guesswork at this point but any abnormal material in a trans is definitely not a longevity enhancement.
This 10spd is starting to be very disappointing and I have my doubts about it's longevity. My 23' had a leak as well and the trans had to be pulled to fix it, sad to see this is still occuring in the 25' model year.
Well, not good news on the saga of this repair.  After more than a week on the rack, it turned out it was not the galley plugs.  The tranny service tech at the GM dealer replaced them, test drove it, reinspected and there was still transmission fluid seeping out at the rear of the tranny.  He did some digging and found a service bulletin issued in 2024 and determined it was time to separate the transfer case from the transmission and have a look.  Upon doing so, he determined the seal between the transfer case and the transmission was the culprit.  So, this was a tad more invasive.  Upon paying a visit to the shop, I talked with the transmission tech directly and he seemed to be competent.  Two more days to wait for the required parts to correct this situation.  Get this...he said he was working on another 2025 duramax/10sp allison tranny in the shop that was doing the exact same thing.  Not good…my bet is that GM will receive more case reports on this and they have a bigger problem stemming from some robotic function that was not set right at the factory at the time these things were built. I learned that this single seal was a fairly new application -- maybe 2024, or maybe starting in 2025.
The wet photo below is from my truck. One seal does two jobs — keeps transfer case fluid where it is supposed to be (inside the transfer case) and transmission fluid in the transmission case.  I truly am not happy about this at all -- it is disconcerting, like having a newborn that needs to have open heart surgery!
I did get the truck back and saw photos of the repair (clean as a whistle as you'll see below).  It was not leaking after a substantial test drive post-repair, so at least that's good.  For now, I'm satisfied with the work done by Bozarth Chevrolet in Lone Tree, Colorado.  As for GM, I'm still disgusted with the quality assurance on this one, given my history with them and their solid reputation.
Glad you got it fixed and sounds like you had a good tech which is half the battle sometimes. Looking at the picture in your thread I had to reread it to realize that wasn't your photo, so maybe they have fixed the front internal cover leak now on these. I have seen the t case leak on the forums, I wonder if it's a bad install like they claimed on the front cover seal as well.
  • 5 weeks later...
Unfortunately, I treated a 2022 Silverado 2500 LTZ diesel for a 2025 Silverado 2500 gas with 10 speed and I have transmission fluid leaking on my garage floor at only 578 miles. I feel confident GM will fix it, but it is a big deflator to your spirit.
Edited by Basco
Add photo
My 2024 2500HD is currently at the dealer for a transmission leak. They called to say that they don't have a transmission tech and that I will need to take the truck to another dealer to be repaired. This is my first GM vehicle and I have been very disappointed in the initial quality. I had a cab mount replaced, I'm on my second side mirror replacement ( they rattle and shake) I've had four recalls done and now the trans leak. I hope this isn't a trend. My son works for GM so I thought I would support the brand. I'm not at all impressed with my very expensive truck.
  • Sad 1
My 22 ram has this issue when I traded it in for a 25 Sierra. Not too happy to hear this is an issue with these trucks as well. I also have leaf spring popping from the cheap plastic pads between each leaf. I've put a bandaid on that for now by putting rubber tire patches between each leaf.
My 2024 2500 Ultimate is the shop with a tranny leak @ 2k miles. They ordered a seal to fix it and after installing new seal it’s gushing liquid now not just dripping. Haven’t given me a diagnosis yet. Can I return this truck and get my $100k back? I don’t feel right paying that amount of money on something that’s already having issues brand new. What’s gonna happen soon as my warranty is up and the transmission goes? What do I need to do to return the truck? I think I’m gonna buy a ram. 2 weeks without a brand new truck with nearest dealership 2 hrs away. Trucks been more hassle than it’s worth. Looks nice that’s about it.
I’m afraid that I may be experiencing a similar issue. My 2025 GMC 1500 Allison Transmission just hit 2,300 miles and the check engine light is on… the screen displayed - low transmission fluid. Not very happy about that as I’ve only made my first payment last week. I will be taking it to GM this weekend.
I hope I didn’t make a mistake going with GM. Do better!!!
Edited by B.rad
Is it leaking underneath? The 10l1000 is starting to become a problem child for these HD trucks and it seems to be getting worse on the 24- up trucks.
    JWeather
    JWeather
  • Who's Online   5 Members, 0 Anonymous, 454 Guests (See full list)
