How much Assembly is Required?
So I finally got a fluid temp gauge installed on the CVT in Raven. Some others in the Mirage Forum I'm in have had them for awhile using a different application and device. I've spent enough on that sort of thing. OMG do these things run hot!!
So the CEL gets tossed at about 258 F and goes into limp mode at 265 F. That's factory. Factory is also a Group II/III blend fluid and 87 C thermostat and not real fluid cooler. More of a fluid heater, attemperator.
Some of these guys, living southern US are running 80+ and towing with a vehicle that has zero towing capacity. Even have a member who went into limp mode on the drive home breaking her in at 85 mph. Lord help that poor car. Seems Joe Average who monitors this parameter is steady over 225 F even in Canada. One member has installed a trans cooler and with a more moderate set of habits his his under 200 F...just. Others in the South West US shudder to look. 230 to 250 F desert crossings.
And we have a power train engineer that has worked for three major Asian auto makers telling us they are set up to die by 150 K. No cooler, mineral oil, no direction or guidance. Not dash monitoring other than an OH CRAP CEL.  Long drain intervals. Internal fluid decay monitoring to deny warranty claims. Resettable only by the factory tool. Stupid expensive maintenance cost.
I'm not listing all I've done to work this out but in my day to day I'm under 185 F and haven't installed a cooler yet. But it's coming. I'll get it under 175 F on my worst day before I'm done. And I'll get what I always get. A long trouble free service life with few limitations.
Fluid life and a factory OCI of 30K with temps routinely over 225F
:idiot:
Russian Roulette anyone?
Parts is parts. CVT or conventional, all have converters, clutches, valve bodies and seals and the fluid has no idea what machine it is in.
Edited by Grumpy Bear
:idiot:
The Redline CVT will save you.
Rapid Disassembly Possible.
You want to run 1 cP oil? Have at. You want to run 350 F? Be my guest. Do you believe in 'forever fills". Wow, glad I'm not you or your powertrain. You want to make irrational arguments about make believe worlds of lubrication regimes? Enjoy the show. I like fireworks.
BMW 10W60 for the E46, M3 and E60. Ford Mustang 5W50. Camaro ZL1. 5W40. Porsche? 5W40/5W50 in the fast sporting stuff. Now what do these bonehead engineers know your run of the mill CLE doesn't?  Evidently allot. Like lubricating an engine on 1 to 3 micron of oil journal film is DUMB.
I will trade fuel economy for engine life all day every day and twice on days ending in Y. But hey, that's me.
Again....Hersey. Speed, Load and Viscosity and viscosity is ruled by...TEMPERATURE. You don't have to run fast to run hot. You need a engineer to call out a 207 to 220 F water thermostat, 197 F TBV and no oil/fluid coolers. Just heaters.
GM has been backpedaling since 2015 on viscosity and cooling. 😏 Ops. Stepped over the line.....
OR keep up with the current trend of self destruction.  Rapid disassemble is certainly possible. They like your money.
First test of VEEPEAK plug in scanner and
ACTIVE OBD for Subaru. 2025 Sube Wilderness Crosstrek AWD.
Edited by customboss
Assemble This!
https://www.jatco.co.jp/english_rele...1031_1557.html
Read it carefully then ask:
1.) How does this friction additive reverse temperature initiated oxidation of the BASE OIL? (It is unavoidable)
2.) How does a friction additive remove the sub 20 micron wear debris the filters can not? (Debris are unavoidable)
From one of the leading suppliers to the auto industry, Jatco!...OMG, what rubbish.
What is the solution to the above two points? Replace the fluid to 1.) Replace damaged fluid and 2.) Dilute or flush debris.
This "new" chemistry does not deny oxidation and contamination....it simply IGNORES it , like it will go away if they promote something disconnected hard enough with a pubic/environmental/governmental need severe enough. Distraction. To what end? $$$$$$$$$$$$ is that enough $$. And one thinks I don't understand business. I understand liars and don't like them.
How's that trust thing for factory engineers holding up? What CLE signed off on that swill? 😏 Was one even involved?
Assemble from Scratch
Sample #1 is a VOA from a batch represented in this entire table and run in a new motor at 3,750 mile intervals.
Sample #1 says we have an oil with a background Nitration of 8 abs / 0.1 mm. According to one CLE 10 abs / 0.1 mm is a hard limit and something is in need of immediate attention if it breaches this value. What does the STLE have to say?:
 Tribology and Lubrication Technology, which is the official journal of the Society of Tribologists and Lubrication Engineers (STLE).
[Quote] Oxidation & Nitration. Oxidation is the gradual degradation of oil, particularly the base stock, that takes place in the presence of oxygen and heat. Excessive oxidation will increase viscosity and can lead to deposits in the form of sludge and varnish. Likewise nitration occurs when nitrogen in the air combines with the base stock to form acids, sludge, and insolubles, all of which degrade the oil. Oxidation and nitration are usually reported together in uoa’s by a unit of measure called abs (absorption per centimeter). It’s important to understand that even virgin oil will show a measure of oxidation & nitration because the test equipment “sees” some of the chemical components of the base stock as if they represent oxidation & nitration. This is particularly true of oils that have some kinds of vegetable esters in the base stock. Thus to correctly interpret a uoa, you need to know the oxidation & nitration numbers showing in the virgin oil. Most labs use 50 abs as the cl for synthetics, above the virgin baseline, and 30 abs for mineral oil. [Close Quote)
But according to one CLE this motor would be in need of a complete tune up every other oil change.
I find the condemnation limit of Oil Analyzers to be quite conservative. (17 abs / 0.1 mm)
"Most labs" 50 unit condemnation limits (ester synthetic) are based on not knowing the virgin values. I know mine. If I didn't the oil is condemned in the bottle on oxidation.
"According to one CLE 10 abs / 0.1 mm is a hard limit and something is in need of immediate attention if it breaches this value."
Your references are not appropriate for used engine oil.
10 abs units FTIR ......NOT A HARD limit but a good RULE OF THUMB for ideal combustion sensing at ring and combustion chamber.
Go with that. Can't fix stupid, pearls to swine, take your choice.
It's a long read and requires a good mental filter but worth the nuggets of gold buried within if you can:
Do Some Required Assembly
https://www.stle.org/images/pdf/STLE_ORG/BOK/OM_OA/Additives/Special Additive Report_Viscosity Index Improvers_tlt article_Sept11.pdf
[Snippet] Placek believes that the added performance requirements for a VI improver in lower-viscosity engine oil may lead to the need to shift to a higher-performing polymer. “Some concern has been expressed about a loss of hydrodynamic lubrication that may accompany the use of lower viscosity oils for improved fuel efficiency,” Placek says. “If high-performance VI improvers can help maintain equipment durability while also delivering improved fuel efficiency, then there could be a shift to higher performance VI improvers for engine oils in the future. [End quote]
I will say this…we really don’t necessarily need higher performing polymers, we just need more MOFT, and there’s other/better ways to get there.
A 0W20 or even a 5W20 can be made with a HTHS over 3.0. MTP30K, Red Line HP, Evolve EvoSyn 5W20 to name three.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
