My truck is listed as Sterling Gray Metallic on the build sheet and online in the GM Financial website, however I noticed that the color in reality is much lighter than what shows up on the GM Financial image as well as the general Chevrolet Configurator website.  Playing around in the configurator my color much more closely matches Slate Gray Metallic. Is it possible something is messed up?  Here are some pictures of what my truck is supposed to look like according to the website, along with what it actually looks like.  What color do i actually have?
Edited by AndrewF
The configurators never exactly match the actual color.  The actual pictures you posted are correct, not the configurator.
Real life pictures or seeing them in person is the best way to see what the colors really look like instead of the B&P renderings.
Edited by newdude
Do you have the window sticker. I have a 2024 GMC in Sterling Metallic. I noticed that Chevrolet lists some of the colors a little different. I just went to Chevrolets website to build an HD truck. I can't tell the difference between Slate Gray Metallic and Sterling Gray Metallic. I looked at a local Chevy dealer's website that has an HD truck in Sterling Gray Metallic and it looks like yours.
57 minutes ago, AndrewF said:
Both colors are very different from each other.  Both are a metallic.  Slate Gray is like a primer gray with a slight hint of blue and silver flake in the metallic.  In most lighting it almost seems non metallic, just gloss.
Sterling Gray is like a silver meets gray.  Darker than the old Silver Ice Metallic it replaced, much lighter than Dark Ash metallic.  Its like a medium silver.
This is Slate Gray -
 New 2024 Chevrolet Silverado 1500 WT Regular Cab #82427 | Classic ...
New 2024 Chevrolet Silverado 1500 LT Trail Boss Crew Cab in Neosho #74056 |  Griffith Motor Company
2024 Chevy Silverado 1500 Crew Cab LT Slate Grey Walk Around Video
Another example of Sterling Gray to add to your two pictures:
New 2024 Chevrolet Silverado 1500 LT Crew Cab in Tilton #V24317 ...
Thunderstorm Gray 1500? - 2019-2025 Silverado & Sierra - GM-Trucks.com
New 2025 Chevrolet Silverado 1500 RST Crew Cab in Mitchell #302052 | Vern  Eide Chevrolet GMC
X2 about the colour samples online being inaccurate.
Also for whatever reason GMC & Chev have different names for each colour.
Gotcha, thanks for the response. That makes sense, also why I’ve never seen any gray/silver trucks darker than mine in this generation. I do wish it was a little darker and closer to the configuration color in reality though but oh well.
And here I thought the actual slate gray color trucks were something completely different than they actually are. I figured it would be a long shot my paperwork was wrong but glad it’s right.
Yeah my window sticker says sterling gray. Online vs real life colors are way off
I like to find a vehicle with the same paint RPO code as the vehicle I want to order so I can view the paint in the daylight.
Got burnt once and want to never let it happen again.
Not at night.
Not at dusk/dawn.
Not if it's raining.
etc.
Internet photos lie.
Paint chips lie.
Configurator shots lie.
Computer and/or TV monitors lie.
Take a shot of the QR code on the truck.
It will have the paint code.
GXD is Sterling Metallic on GMC /  Sterling Grey metallic on Chev
Satin Steel on the '21 , GXD on the '23 (on the right hand side)
GXD from another angle
GXD on same truck same time, same day, another angle -- seems darker?
If you look at my profile picture, that is Sterling Metallic on my 24 GMC Denali.
Either way it looks good! I grew up in an auto repair and refinish (a.k.a. body shop). I wouldn't go so far as to say paint chips lie, but they are a general representation and subject to variations.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
