I noticed the tailpipe looks so shiny like it has a chrome/stainless end, but it isn't is it ?
These HD trucks with no running board look taller yet than if it has running boards hanging down. Good thing with the trim and package you went with that the wheels have the nice center hubcaps that don't cover over the lug nuts, what a pain those would be to deal with any time one wants to check the wheel lug toque etc and they don't look near as nice as these wheels/hubcaps.
Perhaps someone at GM saw this thread and decided to get their butt in gear and get the truck delivered !
Edited by Chuck FB
  • 4 weeks later...
  • 4 weeks later...
1 hour ago, 64BAwagon said:
2026 saleable units have been built and regular production is scheduled for early August.  I am only hearing of  minor changes to interior trim and some option shuffling along with some paint color changes (minor)
The big changes are coming next year in the 2027 models. I heard some of the powertrain changes are being re-evaluated and some will be walked back which I believe is a win for the customers.
I have seen some Ford units at the dealer with a 2 tone paint configuration. Mostly a dark gray or black lower accent or a dark roof color. I am glad to see some 2 tone styling coming back. I assume GM will follow suit if Ford is doing it. If GM does the predictable thing it will likely be a special edition on the higher trim levels only.
Order guide has been live for some time now.  Hardly any changes other than colors and two new wheel RPOs.
2026 HD order guide changes - Vehicle Order Guide
There won't be any interior trim changes with so little time left on the current T1s.
Qa@64BAwagon Did the aftermarket 2 tone for K2XX models appear in the US? I saw a few here in Canada during the model run. It looked pretty good, but the CHEVROLET graphic on the tailgate was a bit off. Im not sure if it was the font or size that didnt look right to my eyes.
There is a thread in the K2XX 1500 forum.
That all being said, I'm not sure if the T1XX 1500s w/ the swooping feature line in the fenders & front doors is conducive to a 2 tone.
Edited by revrnd
