Hi everyone,
Let me start off by saying I HAVE NEVER posted in a forum before so go easy on me lol.
I have a 2024 Silverado 1500 RST as a lot of you know it does not have a 12v plug. That being said i have a new born and was just gifted a back seat camera. I am looking for a way to use this camera only when i have the baby in my car.
I cannot stand the look of wires ALL OVER so i really wanted to hide the wires somewhere inside the cup above the infotainment system. Please help me out here, do i need to drop all this money on upfitter switches or can i get away with a simple rocker switch IDK.
Side not i would also love to some how hide my wireless chargers usb cable in dash as well... Let me know if you have experience in that as well lol
I greatly appreciate any help you can provide!
9 hours ago, Matthew LaCava said:
Hi everyone,
Do you have the full center console in your RST or do you have the front row center seat w/armrest? What kind of wireless charger do you have?
If you have long enough of a cord you can do like I did with my dash cam where I have it plugged into the USB port on the dash and snuck the cable between where the bottom area of the dash is just below the HVAC controls and the top right edge of the center console. I then routed the cable behind the glovebox in the dash (had to remove the right panel on the center console to help feed the USB down and through the area and I used a flexible grabbing tool to push it through) and routed it up through the A pillar and across the windshield at the top and then have the cable coming out the plastic shroud around the forward facing collision avoidance camera.
Are you mounting your phone down on the dash or are you considering mounting it up by your rearview mirror?
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
