Will be putting on a 2/4 drop in the next few weeks and I’m trying to find some wheels outside of the OEM stuff and the Vossens/Cosmis/Welds that are crazy expensive per wheel. I found a set of DUBs I like, but I am just posting to see what all kinda wheels y’all are rolling with. I’ll probably be going with a black wheel since my truck is slate gray
Post pics when you get it dropped and when you decide on wheels. Thinking about a 2/4 and 24’s on mine too. I have 22 replicas on it now stock height.
On 1/22/2025 at 11:26 AM, Delson0 said:
You get what you pay for…
I know that. But I also know there are nice sets of wheels out there that aren’t $700 a piece. Just trying to get ideas
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
