14 hours ago, davester said:
Sure, GM has been paying HUNDREDS of millions of dollars in fines to the US gov't for exceeding CAFE standards because they get what from the oil companies?  And that's just for slightly exceeding them.   If a bigger plastic tube would give them even 0.1 mpg more, it would have been put on all their vehicles years and years ago.
Yes, the CAI can give you a couple more HP, at WOT.  Where you spend basically 0% of the time.
Exactly, he talks about dyno pulls with a CAI giving more hp there is alot of fluctuations in dyno pulls from hood open vs closed tire pressure fan close or far back even how tight the straps are etc. NO 2 dyno pulls are the same which can vary 3-5%. Dyno pulls can be easily manipulated.
Cold air intakes and higher flowing exhaust does open up additional power. Over the years the manufacturer has been able to increase flow with less noise. I’ve seen studies outside the manufacturer that performance and fuel mileage does increase by opening up the flow in and out. Less so over the years. Because they’re more efficient. You’re seeing manufacturers putting in switches called sports mode that open the exhaust among other things. Even in trucks. I did it all over the years. Saw benefits. Honestly I wanted the sound. The debate on whether the bang for buck is a pronounced. Who cares? Most people are way past being cost effective. How many of us drive base models? Or cars? They’re way more efficient in so many ways.
On 6/28/2025 at 1:01 PM, Red6.2 said:
What I ended up doing was getting a GM performance intake elbow and keeping the stock airbox in for a smoother airflow curve. Worked good and then when the parts became available for the GM performance intake off the 2025 6.2s I got one of those airboxs. My dealer told me the refresh trucks didn’t need the calibration to put them in. Just disconnect the battery cable. So far have had no issues and can tell a difference in having the GM performance intake in. Truck seems to shift better and feels more responsive.
That appears to be a nice system and sure looks nice.
A friend of a friend were selling their 2021 Silverado 6.2 and moving on to another manufacturer.  After reverting back to OE, he was planning on selling his CAI system, but I was able to barter some services he needed at his house and got the CAI, along with some cash.
So I'll give this Cold Air Inductions brand CAI a go, along with this Stillen Air Intake Scoop I installed over the weekend.  With that intake scoop, I removed the passenger top aero shutter fin also, for constant air flow here in SW Florida.  Throttle response should be noticeable, while hoping to gain cooler air between the CAI/Stillen system and monitor if slight mileage gain, compared to what's advertised.
Update - So I installed this CAI last night and really easy install.  I much prefer the "cleaner" look of the engine bay, with a CAI.  Personal opinion here, I think it looks better than the S&B CAI I had, which filled a lot of space and also keeping with keeping OE MAF harness, no extensions (Cold Air Inductions system).
I'll see what the numbers tell me after a month of driving to work (~25 miles one way), with this Stillen intake and CAI combination, versus the S&B.  From the short time of running errands though, I do like the sound and pick up, with finally mating to my LT headers/mid-pipe/Corsa exhaust.
Edited by DenaliSS
spelling
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
