I got my 2016 HC in 2019 with 35K miles.  I was finally convinced by a trusted friend master mechanic to install a catch can with baffles, which I did.  I empty it regularly, every 1000 miles in warm, 500 in winter to keep ice/condensation to a min.  Truck now has 80K miles
I did the valve clean procedure with Lucas GDI Valve  cleaner spray.   Disconnected the intake and shot the spray in past the MAF (which I disconnected also) Son kept the RPMs at 2K, shot spurts  in for about 8 minutes til can empty.  Never stalled or sputtered, heard slight increase in RPM with every squirt.  Let it sit for 20 minutes per the directions, then put it all back together and drove.  Didnt see a single puff of blue smoke.  Had to reset the CEL, probably lit due to the disconnected MAF?
Truck actually was running smoothly and still is, but was convinced to do the simple procedure for this GDI engine.
Hope that indicates the catch can is doing it's job keeping crud off the valves.
I also do the DGI Valve Cleaning but with the CRC stuff, as it contains the largest amount of PEA (PolyEther Amine) that is 150 times more concentrated on the intake valves than any premium fuel additive, which is what dissolves the carbon. I use it on all my GDI cars (BMWs). I have not been convinced about the catch can mode, as I feel it's fine for the engine to burn this mostly water & oil vapors, which I don't think is any big deal. Your catch can actually condense these vapors, so they become liquids. Each to their own on this mod, sort of like the cold intake systems over the OEM air filters. I'm too old for any little HP difference. LOL   BTW, I'm an old school shade tree DIYer. Hard to teach this old dog/Leatherneck new tricks...LOL
BTW, even BMW has added port injectors to their latest GDI engine (B58) to help eliminate the carbon build up. Enjoy your ride!
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
