21 hours ago, Tom73 said:
I don’t see where P0016 would be involved. It is just the alignment/timing between the crankshaft and the camshaft. This recall is the crankshaft journals and bearings.
The P0016 code indicates a problem with the correlation between the camshaft and crankshaft positions in your GM vehicle, meaning they are not in sync. Common causes include a damaged timing chain or belt, faulty sensors, or issues with the variable valve timing system.
20 hours ago, Tom73 said:
Good reading. But don’t see how the camshaft position can be affected by the crankshaft bearings. Unless the bearings are so bad the crankshaft is moving around in the main journals.
Bottom end seizing up = spinning off phase of the camshaft.  VVT could be trying to compensate and it hits or exceeds that +/- 11 degree limit in doing so.
"The deviation of the relative camshaft position is greater than −11° in one direction or greater than 11° in the other direction (measured in degrees of the crankshaft)."
Edited by newdude
Extended warranty for those that pass inspection. Per GM Authority:
Vehicles impacted by the recall will be inspected by authorized GM technicians. If either of the manufacturing defects are detected, the engine will be replaced. For vehicles that pass inspection, GM will provide an oil and filter change using 0W-40 Mobil 1 Supercar oil, as well as a new oil fill cap to match the revised spec. Engines that pass inspection will also receive a new special coverage program that extends warranty protection for 10 years or 150,000 miles from the vehicle’s in-service date, whichever comes first.
https://gmauthority.com/blog/2025/05...anty-coverage/
I'm currious what inspections will be conducted to check for the defects?
Oil analysis?
Visual scope?
Audio or vibration monitoring?
It will have to be something that does not require the engine to be disassembled.
Just my speculation but assume that crankshafts are supplied by multiple vendors. Apparently some out of spec crankshafts were in the mix so GM has to figure out which engines they went into. Not sure how they would do this other than to drop the pan and check the numbers on the crankshaft. If it is from the bad batch you then get a new engine. If not part of the bad batch you will get an oil change, new oil cap, and a 10 year 150k mile warranty (from inservice date).
a 10 year 150k mile warranty is not bad for the inconvience.
Motor oil geek, may help with 6.2 confusion. Also explains why they use start stop and cylinder deactivation. 6.2 fixed? Does it help or add to the confusion? On YouTube.
Edited by KARNUT
If you are using dexos licensed oil, how could anything go wrong?
Anyone heard anything more on how/when this recall to happen? My dealer is still in the dark as to when it starts and what the inspection will consist of. They still waiting further instructions from GM.
Anyone heard anything more?
Its releasing in phases.  We've done the 4 used in stock, and 2 customer vehicles so far.
How long does it take to do an inspection?
My dealership called me Friday wanting me to bring mine in. The lady was like this is so important because its a safety recall....lol
I told her Id get back to her since we were building desks for our office at the time. :D
Figure an hour.  Pull it in, get it on the lift, install the sensor, get the programs running (which its GM and they've been touch and go with their recent security upgrades) and then run the test.  If the truck is cold there's about 10-15 minutes of oil warmup time before the test will run/allow you to record the sample.  Oil temp has to be 90C or higher.
Edited by newdude
I got my recall notice from GM Canada a couple of weeks ago. I took it to the dealer and they said there's no need to do anything. I'm under warranty until 100,000 km (50,000 on it now) so just leave it; if the engine fails it will be covered under warranty. He said why change the engine now when you can get it changed at 99,000 if it needs it.
Sounds questionable. I'm going to phone GM Canada and ask them.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 234 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
